• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
2
Premiere Pro 2019 Legacy Title Tools & Actions
Explorer ,
Oct 21, 2018 Oct 21, 2018
I just installed Premiere Pro 2019 (version 13). I prefer using the Legacy Title tool because I find it more straightforward and easy to use. Except... on this latest version I find that when I open it, the tools and actions displays are always hidden. I have to click on the little horizontal bars and call them up. Is there any way I can change this so that they simply appear whenever I open the titling tool? Thanks,
J.
Views
29.1K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Oct 23, 2018 Oct 23, 2018
Votes
Translate
Translate
Adobe Employee ,
Hi James_B_M,
Sorry to hear you are facing this issue.
We have identified this issue and working on a fix. Till then you can use these workarounds,
1. Reset the workspace by following this path,
Window > Workspaces > Reset to Saved Layout
2. You can use a different workspace,
Window > All Panels
I hope it helps.
Thank you for your patience,
Shivangi
Votes
Translate
Translate
Report
Report
Explorer ,
Hi Shivangi,
I tried both those suggestions but neither did the trick. The strange this is, the tools and actions boxes do appear the first time you create a new title, but they disappear if you reopen the title or create a copy of the title. Quite strange. In the little dialogue box that appears from clicking the three little horizontal lines, the tools and actions options don't retain their check marks the way "Safe Title Margin" or "Safe Action Margin" do. I look forward to the fix for this problem. Thanks,
James.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Yes, the issue is getting reproduced at our end as well.
Please share a  screenshot of your workspace when you select Window >> All Panels
Shivangi
Votes
Translate
Translate
Report
Report
Explorer ,
With the title tool open I selected  Window >> All Panels. The title tool disappears and I'm left with this generic workspace, which is different than my custom workspace:
Votes
Translate
Translate
Report
Report
Explorer ,
I would really rather not have the all panels window using up valuable real estate on my screen. I only need those title tools and actions options when I'm editing titles, otherwise I don't need to see that panel.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
I would really rather not have the all panels window using up the valuable real estate on my screen.
We understand your point. There are multiple instances reported for the same issue. It is under investigation so this is the only workaround we can provide as of now.
I will advocate on your behalf.
Shivangi
Votes
Translate
Translate
Report
Report
Community Expert ,
They're working on a fix.
In the meantime, that's about all you can do. Start with the all panels space as Shivangi shows, and modify till it is workable; save that. I moved the title viewer into its own panel group, then added the other tools til it looked like the traditional title space. I modified so my most used editing options were available, then saved that as the new space, called, for example, "Old title Space." Then I just click on the workspaces toolbar for that space when needed.
Votes
Translate
Translate
Report
Report
Explorer ,
Okay, thanks everyone!
J.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Oct 24, 2018 Oct 24, 2018
Happy to help
Votes
Translate
Translate
Report
Report
Community Expert ,
See this post in another thread. I describe 4 workarounds, with screenshots of 2 custom workspaces. Ann's screenshot above illustrates workaround 2. Spoiler alert: workaround 1 is to use Essential Graphics. lol.
Re: Legacy Title Options Keep Disappearing
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Oct 30, 2018 Oct 30, 2018
James_B_M,
Sorry about this.
My guess is that Legacy Title options probably won't be around forever. It takes valuable engineering cycles to maintain, and, to my knowledge, it's no longer being developed. My advice: best to start using the newer tools to become familiar with them so by the time that happens, you've already moved on.
Kevin
Votes
Translate
Translate
Report
Report
Community Beginner ,
Oct 31, 2018 Oct 31, 2018
Kevin,
That would be fine if Essential Graphics had the full functionality of the Legacy Titler. It doesn't. And it's nigh-upon contemptuous of the customers to take the Legacy Titler away without replacing its functionality.
Votes
Translate
Translate
Report
Report
Community Expert ,
joshuab93692620  wrote
...full functionality of the Legacy Titler...
It is getting there. I have been slow to use the essential graphics, but am doing so more. And some of the early limitations that I recall are being addressed (e.g. rolling credits).
What limitations do you see? I am not saying they do not exist, but we can help advocate for getting the new methods complete.
In the meantime, see my link in post 14 above. I just put it through the paces, and even though some users had issues, my workarounds 3 and 4 (creating custom workspaces beginning with the All Panels workspace) seem to be working. Once in that custom space, I can add and edit legacy titles and both the docked "titler" (workaround 3) and floating (workaround 4, the traditional look) stay put.
Votes
Translate
Translate
Report
Report
Community Expert ,
That does not work on my end. I even have to reset it in All Panels every time I want to use it.
Votes
Translate
Translate
Report
Report
Community Expert ,
Odd. I have the 2 custom workspaces on the workspace bar. I'm not stressing them, but just did a dozen creates/edits/whatever, and the assembled titler arrangement is intact. If I close one of them, I can revert to the saved layout and it is back.
Has anyone else tried the custom workspace and had it fail?
So the only "guaranteed" workaround is All Panels and reset as needed. Ugh.
Votes
Translate
Translate
Report
Report
Community Expert ,
Well said: ugh.
This forces me to use EG as this workspace issue is getting on my nerves.
Votes
Translate
Translate
Report
Report
Contributor ,
Jan 24, 2019 Jan 24, 2019
Quote:  What limitations do you see? I am not saying they do not exist, but we can help advocate for getting the new methods complete.
You can't make nice glowing text, you can't have a large soft shadow, there are no styles that can be created or chosen--pretty much 90% of the options are just completely missing.  If they do get rid of legacy titles, I'll have to use Photoshop to create titles, which is a pain, as I never do titles without soft-looking effects.
Right now I'm still using 12 out of fear of problems with legacy titles.
Votes
Translate
Translate
Report
Report
Community Expert ,
Jan 25, 2019 Jan 25, 2019
Thanks for the info.
Votes
Translate
Translate
Report
Report
Explorer ,
Feb 04, 2019 Feb 04, 2019
How do I get to this title screen on 2019 version?
I always use ctrl+T shortcut but it doesnt work now.
Thanks!
Votes
Translate
Translate
Report
Report
Participant ,
File > New > Legacy title;
also double-clicking on a title in the timeline / media library
Is that what you were looking for?
Votes
Translate
Translate
Report
Report
Explorer ,
I did find it on:
But this window didn't popup when I double-clicking on a title in the timeline.
Also when I did click on Ctrl+T shortcut, title is created in the timeline but I can't find it at all in the project window (Where I can see all the files list in my project (pictures, video etc..))
What can I do in both of this problems?
Thanks!
Votes
Translate
Translate
Report
Report
Participant ,
Re: Ctrl+T
Ctrl [or cmd]+T creates a text title the 'new' and preferred way going forward. These are not assets which list in the project media library like legacy titles; they live only in the timeline (to the best of my knowledge) and are managed via Effect Controls and/or the Essential Graphics panels.
RE: Legacy title panel not appearing when legacy title is double-clicked from timeline --
This may be related to the OP issue of the panel being placed incorrectly or with inappropriate panel locations. On my end, I have since 'reprogrammed' my Legacy title window location with my workspace as per the solution flagged in this thread, so when i double click a legacy title it does appear as a window. It may be your Legacy title is appearing elsewhere in your workspace or off screen.
Votes
Translate
Translate
Report
Report
Explorer ,
According to what you wrote here:
Can you explain to me how exactly I can "reprogram" my Legacy title window location with my workspace?
I didn't understand it just from what you wrote here.
Thanks!
Votes
Translate
Translate
Report
Report
Community Expert ,
Feb 05, 2019 Feb 05, 2019
The problem with legacy title panels was introduced with 2019 was fixed in 2019.0.2. See this thread for more info and workarounds if this is your issue.
Votes
Translate
Translate
Report
Report
