• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Add text if ParagraphStyle is found
Participant ,
Oct 22, 2018 Oct 22, 2018
Dear scripters,
Can you let Indesign to look for an specific paragraph style and if found than add an specific text before that line see picture below.
Before
After
Already thanks for you'r help.
Greetings.
TOPICS
Scripting
Views
927
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Oct 22, 2018 Oct 22, 2018
Try the following code
function addTextToPara(pStyleName, prefixText)
       app.findGrepPreferences.appliedParagraphStyle = pStyleName
       var paraList = app.activeDocument.findGrep()
       for(var i = 0 ; i < paraList.length; i++)
            paraList.contents = prefixText + paraList.contents
       app.findGrepPreferences = NothingEnum.nothing;
//Change the argument with the name of the paragraph style you want to search and the text you want to add before that para
addTextToPar
Votes
Translate
Translate
Community Expert ,
addTextToPara("Paragraph Style 2", "<1>")
-Manan
Votes
Translate
Translate
Report
Report
Participant ,
Hi Manan,
That worked perfectly!
Many thanks.
Votes
Translate
Translate
Report
Report
Participant ,
Oct 28, 2018 Oct 28, 2018
Hi Manan and others,
Is there also an way the text would be at the end of an paragraph?
Like <1>here is some text<1>
Again thanks for you'r help!
Greetings.
Votes
Translate
Translate
Report
Report
Community Expert ,
In place of the below line in the code mentioned before in the thread use the line that follows it
//Replace this
//With this
paraList.contents = prefixText + paraList.contents + prefixText
-Manan
Votes
Translate
Translate
Report
Report
Participant ,
Wouw that's an extremely fast answer! Thanks!
It is placing the text alright but at the beginning of an new paragraph.
This
Becomes this
I'm wondering if there is an way you can tell indesign that there is an end of an paragraph (without using /n or /r)?
And if found add <2> so you get <2>TEST<2>.
Greetings.
Votes
Translate
Translate
Report
Report
Community Expert ,
I am not sure why you don't wanna use \r or \n for check condition. The following works for me
       var paraList = app.activeDocument.findGrep(true)
               if(paraList.contents[paraList.contents.length - 1] == '\r')
                    paraList.insertionPoints[-2].contents =  prefixText
               else
                    paraList.insertionPoints[-1].contents = prefixText
-Manan
Votes
Translate
Translate
Report
Report
Participant ,
Oh, but this works perfectly, can I double give you the credits?
The reason I'm scared to use \r is that sometimes in the story there is an \r and sometimes an \n.
I thought when you use that variable the script puts in the middle of story 's an <1> and I only wanted it at the end of each lines of text with an specific paragraph style but that's not the case, I see now.
You look for an specific paragraph style and the end of each paragraph style it always ends with an \r. I was thinking wrong.
Again for the second time thanks for you'r help!
Greetings.
Votes
Translate
Translate
Report
Report
Community Expert ,
Oct 29, 2018 Oct 29, 2018
LATEST
Hi beh_gras_beh ,
is this thread related to the one below? Guess, yes:
GREP style in paragraph with ~b \r or \n?
Regards,
Uwe
Votes
Translate
Translate
Report
Report
