3 Replies Latest reply on Dec 5, 2018 9:56 AM by farhanOfficer
    Exprot video file size abnormal
    志賢張52743150
      Hello
      I update to Premiere Pro 2019 in yesterday
      Now i export video, setting bitrate 100Mbps, estimated file size 2671MB
      But export file size only 912MB
        • 1. Re: Exprot video file size abnormal
          Kevin-Monahan Adobe Employee
          Hi 志賢張,
          Are you using hardware acceleration for export? That could be the key. Let us know.
          Kevin
          • 2. Re: Exprot video file size abnormal
            eikonoklastes Level 4
            This is normal. Depending on the content of your video, it could end up with much lower sizes than the estimate. Large blocks of the same colour and/or little movement in the video will produce smaller file sizes.
            You can test this with a new sequence, just place a Black Video in it and set its length to something around 15 minutes. The export dialog will estimate a file size over 1 GB with the H.264 High Bitrate preset, but the exported clip will only be a couple of MB in size.
            • 3. Re: Exprot video file size abnormal
              farhanOfficer
              Hey Kevin,
              I seem to be having the exact opposite problem.
              I need to export videos in a box (1080x1080) format so I use the "Match Source- High Bitrate" option. For previews I need to export a smaller version so I reduce the bitrate to get an estimated file size of 8 MB. But the exported file turns out to be 25 MBs.
              I'm using Premier 2018. Can you help me with correcting this?
