I often use the Transform>Distort tool on a rectangular selection (or an entire rectangular image in a separate layer of a many layered file). When using Photoshop 2019, the I am not able to pull a corner of the selection in both the x and y axis at the same time. One of the two axises remains fixed. This is a problem for the work I'm doing. Is there some button or tool preference that needs to be (un) checked. Driving me crazy.
As a note, if I open the same file in Photoshop 2018, I can drag a corner of the selection when using Transform>Distort freely. But I can't in Photoshop 2019, only in one axis at a time. A real problem.
Thanks.
Adobe change the behavior of transform. You can add a PSUserConfig to correct this problem.
Photoshop now transforms some layer types (such as pixel layers, type layers, bitmaps, Placed Smart Objects) proportionally by default. Shapes and paths, that is vectors, still transform non-proportionally by default.
When transforming a layer, you sometimse no longer need to hold down the Shift key while dragging a corner handle to resize a selected layer to constrain its proportions. Sometimes you drag a corner handle during transform and move it, the layer resizes proportionally. Holding down the Shift key now sometimes resizes non-proportionally when you drag a corner handle during transform
JJMack - worked for me. Great job. Thanks!
The "PSUserConfig.txt" preference did not work for me.
Am I dreaming? I used to be able to make a four sided figure conform to any other four sided figure by using the Distort Tool. I just selected one figure , chose Distort and dragged each of the four corners of the object to the four corresponding corners of the other.
Like taking a picture of piece of paper at an angle, and correcting it so that all four corners are 90º.
Can’t do that any more in CC 2019. And Adobe erased all of my previous versions of Photoshop when it upgraded.
Hi
You can re-install previous versions from the CC app
I do not know why anyone would want a new inconsistant behavior
Thank you, JJ. I have saved your script should I need to alter my settings in the future. For now, holding down the shift key is working, allowing me to transform>distort non-proportionally (i.e. moved in both the x and y axises simultaneously) in the files I'm working on. Thanks for the tip!
The new functionality seems to be holding the SHIFT key to be able to freely warp. Lots of weird changes to how the shift key modifies tools.
