2 Replies Latest reply on Oct 23, 2018 2:35 PM by Lorne Resnick
    Bookmark editing position...
    Lorne Resnick
      Is there any way to bookmark where I left off in editing a batch of images?
      For example: I have 5,000 images in a folder that I am going through and assigning stars to. If I get halfway through and then have to go to another folder in LR, and then go back to that same folder it's hard to know where I left off as LR goes to the beginning of the folder, not where I left off. Of course, I could write down the images number I left off, but that is not practical if I am doing it with several folders.
      Anybody?
      Lorne
        • 1. Re: Bookmark editing position...
          I don't normally use color coding. So I have on occasion set a color code on an image as a bookmark. Then when returning to that folder I can filter on the color to find that image, and then remove the bookmark to continue from that point. It's a little clumsy, but it works.
          • 2. Re: Bookmark editing position...
            Lorne Resnick Level 1
            Jim,
            Good suggestion. Yes, I have done exactly that before, I should have mentioned that. But I was looking for something a little less clumsy.
            Ideally, LR would have a preference that enabled me to either "go to the 1st image or the last image viewed" once I return to a folder.
            LR gods, are you listening? :-)
            Anyone else have a more elegant solution while I wait for the LR gods to answer?
            Lorne
