• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
CFCs & CFInvoke
LEGEND ,
Jul 07, 2006 Jul 07, 2006
I am attempting to play with components and invoke them inside web pages. I
created a simple CFC (news.cfc) to pull the latest news story from the
database:
<cfcomponent>
<cffunction name="LatestNews" access="public" returntype="string">
<cfargument name="myArgument" type="string" required="false">
<cfquery name="news" datasource="#Request.MainDSN#">
SELECT News_ID, Story,"Date" FROM ms411.news ORDER BY "Date" DESC
</cfquery>
<cfset myResult="foo">
<cfreturn MyResult>
</cffunction>
</cfcomponent>
In the web page I want to display the results I have:
<cfinvoke
component="news"
method="LatestNews"
returnvariable="returnVar">
</cfinvoke>
Then I have, in the area I want to display it:
<cfoutput query="returnVar">
<tr>
<td>#Date#</td>
</tr>
<tr>
<td>#Story#</td>
</tr>
</cfoutput>
I keep getting this error:
Attribute validation error for tag cfoutput.
The value of the attribute query, which is currently "returnVar", is
invalid.
I have the Coldfusion MX Bible sitting next to me and (on page 452 for those
of you that have it) it give the same example. Same invoke, same 'cfoutput
query = "returnVar"''. Why am I getting this error and how do I fix it?
Thanks!
Wally Kolcz
Developer / Support
TOPICS
Advanced techniques
Views
547
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
because you're CFC is returning a string and not a query?
HTH
Tim Carley
www.recfusion.com
info@NOSPAMINGrecfusion.com
Votes
Translate
Translate
Report
Report
LEGEND ,
If you run this code:
<cfdump var="#ReturnVar#">
you get
foo
Right? Read your function and see if you can figure out why.
Votes
Translate
Translate
Report
Report
LEGEND ,
I changed it to 'query' rather than string, but now I am getting:
The value returned from function LatestNews() is not of type query.
and it is directing me to:
Votes
Translate
Translate
Report
Report
LEGEND ,
Because I am have <cfset myResult="foo">. That is what DW gave me to work
with. I didnt have it originally, but it was giving me an error for not
setting a variable.
What works in the book, isn't working in DW and using CF Server MX 7. I am
confused....
Votes
Translate
Translate
Report
Report
LEGEND ,
As well as the returntype of your function being a string instead of a
query.
You are also not returning the query.
<cfreturn MyResult>
That should be <cfreturn news> so that it returns the query you created.
You can remove the <cfargument ...> line, since you are not using it.
Unless you plan to add functionality later that would make use of the value.
To jump start you an better practices. You should var declare your news
variable so that it is local to the function and will not run into
problems with other variables named "news" in other places of your code.
<cfuntion ....>
<cfset var news = "">
Secondly you should pass in your dsn value to the function, not have the
function relay on a value existing in the calling code block. This
would then be a reason for a <cfargument ...> tag.
<cffunction ... returnType="query">
<cfargument name="DSN" requrired="true" ...>
<cfquery name="news" dataSource="#arguments.DSN#"...>
<cfreturn news>
</cffunction>
Your invoke then would add an argument parameter, there are two ways you
could do this.
> <cfinvoke
> component="news"
> method="LatestNews"
dsn="#request.MainDSN#">
> </cfinvoke>
OR
> <cfinvoke
> component="news"
> method="LatestNews"
<cfinvokeArgument name="dsn" value="#request.MainDSN#">
> </cfinvoke>
> database:
> <cfcomponent>
> </cfquery>
> <cfreturn MyResult>
> </cffunction>
> </cfcomponent>
> <cfinvoke
> component="news"
> method="LatestNews"
> </cfinvoke>
> <tr>
> <td>#Date#</td>
> </tr>
> <tr>
> <td>#Story#</td>
> </tr>
> </cfoutput>
> invalid.
> Thanks!
Votes
Translate
Translate
Report
Report
LEGEND ,
I get without something.
Variable MyResult is undefined.
In the CF MX Bible, all they have for a component is (minus the long stuff):
<cf component>
<cffunction name="GetCompany" returntype="query">
<cfargument..>
<cfquery...>
SQL
</cfquery>
<cfreturn companyRec>
<cfcomponent>
At no point in their examples do they set a variable for the cfreturn, which
is giving me an error if I don't.
I am trying to learn this.
Votes
Translate
Translate
Report
Report
LEGEND ,
<cfreturn MyResult>
you're returning a string...name you're query "MyResult", remove the
cfset...
HTH
Tim Carley
www.recfusion.com
Votes
Translate
Translate
Report
Report
LEGEND ,
which is giving me an error if I don't.
I suspect if you look at the cfquery tag, it has ...Name="companyRec".
This sets the query recordset to the variable 'companyRec' that is
returned in the <cfreturn ...> statement.
> <cf component>
> <cfargument..>
> <cfquery...>
> SQL
> </cfquery>
> <cfcomponent>
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
Thanks a ton Ian. That makes a lot more sense to me. I got it to work!
Votes
Translate
Translate
Report
Report
Resources
Documentation
