1 Reply Latest reply on Nov 5, 2018 2:27 PM by Kevin-Monahan
    Premiere Pro 2019 Max Bitdepth Brightness
    felixf80126224 Level 1
      If I turn on the maximum bitdepth for a sequence every clip in this sequence gets a lot brighter (like 3 stops). If you play the clips without high quality playback enabled they get back to their normal brightness. It would be fine if you had to enable the high quality playback to view the clips correctly but  if you turn on the comparison view in the program monitor, it shows the clips with their normal (too dark) brightness again. This is really annoying as you cannot see how the footage looks correctly graded while playing the clip or if you want to look at them side by side.
      The clips in my sequence are all 12bit.
      This was not the case with the 2018 version.
