• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
New 1080 ti is baking my CPU
Explorer ,
Oct 25, 2018 Oct 25, 2018
Hi all,
I recently upgraded my editing PC from a 1050 ti to a 1080 ti, which I was really excited about, but upon running a few render tests, it really seems to do a whole lot of nothing while my CPU is breaking it's back:
My issues are:
1. I'd like the 1080 ti to carry a bit more of the weight
2. I don't want to turn my CPU into a potato chip
Am I just misunderstanding the purpose of a high speed GPU? Things seemed a lot more balanced with the 1050 ti.
System specs:
Intel Core i7-7700K 4.2ghz
32gb DDR4-3000 Memory
Gigabyte Ultra Gaming Z270X ATX
Windows 10 (64)
Corsair RM850x power supply
Thanks so much!
Andrew
Views
759
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Oct 25, 2018 Oct 25, 2018
Again, this has to do with component balance. If your GPU was running near 100% but your CPU wasn't quite running at that level, then the GPU is (like I said earlier) a tad underpowered. (Ideally, both the CPU and the GPU should have been running at relatively high levels for this GPU-accelerated render.) And like I said, there are unfortunately no cost-effective GPU upgrades for your particular situation right now.
On the other hand, if neither the CPU nor the GPU were running anywhere near thei
Votes
Translate
Translate
LEGEND ,
The problem is the 1080ti is overkill for that CPU. The CPU is a fast 4-core rig, but note it isn't even maxing your RAM? The CPU is the primary gatekeeper for all processing, and as the CPU's cores/threads/RAM have things to send to the GPU, it gets work to do.
That 1080 is so fast at what's being sent it's just idling, really. And you're right, the 1050 was more balanced for that CPU. To start pushing that CPU, you'll need at least 8 fast cores I would think. And then you'd first note your RAM was a lot heavier in use ... might even need to up the RAM a bit. Safeharbor11 and some of the others would handle those details better.
Neil
Votes
Translate
Translate
Report
Report
Explorer ,
Thanks for the reply!
So that answers my first issue (and I'm certainly not opposed to upgrading the CPU and mobo in the future), but what about the second issue regarding the CPU overload? I'm not sure I follow as to why it's running at 100% now and wasn't previously with the 1050 ti.
Andrew
Votes
Translate
Translate
Report
Report
LEGEND ,
On the other hand, if neither the CPU nor the GPU were running anywhere near their full utilization for that render, then the bottleneck would have been somewhere else in your system, such as a misconfiguration of the software and drivers.
Votes
Translate
Translate
Report
Report
Explorer ,
Well apparently my memory of CPU usage was way off. I swapped out the cards and, yes, things are much more balanced, but the CPU is still maxed out and hot.
I think I might send back the 1080 and invest in a better fan...
Thanks guys!
Andrew
Votes
Translate
Translate
Report
Report
Explorer ,
Nov 15, 2018 Nov 15, 2018
I always hate when I'm looking for solutions to problems and the forum never resolves the issue.
For those of you keeping track at home, my CPU is 4.2ghz. I continued to delve into the details and found that it was running at 4.4-4.5ghz.
Going through the bios for my Gigabyte GA-z270x Ultra Gaming motherboard, I found that the "Intel Turbo Boost" was set to Auto (default setting?), which was overclocking it and causing the extreme temps. I shut it off, moved everything from an older model case to a Fractal Design Focus G, and installed a Mugen 5 Rev. B CPU cooler with dual fans. The same exporting process seen above now runs at about 62C.
Votes
Translate
Translate
Report
Report
LEGEND ,
Simple. You are asking too much of that GPU, especially when it's your CPU that's the limiting factor. In CUDA applications that demand a balanced configuration the i7-7700K, having only four cores and eight threads, cannot keep up with the GTX 1080 Ti. In fact, you really need a far more expensive CPU platform with an 8-core/16-thread CPU just to come anywhere close to fully utilizing that GTX 1080 Ti.
Granted, your previous GTX 1050 Ti was a bit underpowered relative to the i7-7700K. But a GTX 1060 or 1070, which would have been more apropos for that rig, would have cost you more money than is justified by the performance boost. Therefore, you just wasted your money right there.
Votes
Translate
Translate
Report
Report
Guide ,
Hello Andrew
The 1st question is why did you upgrade to a 1080ti?
Yes it is one of the latest Pascal based cards and is very powerful but in day to day computing and rendering you won't see any spectacular results compared to the 1050ti. And look at that power draw. No wonder you are cooking. I hope your PSU can manage this card. 75watts compared to 250 watts is a MASSIVE jump up in power consumption.
The thermal design power (TDP), sometimes called thermal design point, is the maximum amount of heat generated by a computer chip or component (often a CPU, GPU or system on a chip) that the cooling system in a computer is designed to dissipate under any workload.
I would recommend better cooling in your rig asa start and that too will draw more power. Most people feel that bigger GPU will yield better results in PP and AE and whilst this is sometimes true the amount of differences are really minimal (I am talking seconds worth of difference). The power of full GPU rendering is a while off and until then CPU and RAM are key points to be addressed for better performance.
Trust this helps you
Mo
Votes
Translate
Translate
Report
Report
Explorer ,
Nov 17, 2018 Nov 17, 2018
I originally purchased the 1080 ti to help speed up my time in PP, AE, and ME, but after this discussion I understand that those resources were misplaced and thusly returned the GPU and installed the 1050ti. And as you said, there was very little difference in system performance between the two cards.
Regarding power, I did upgrade to an 850w PSU before installing the 1080 ti, so that wasn't really an issue.
Again, I managed the heat issue through the bios setting and upgrading the case and fan system and things are working great. If I'm reading this (2014) article correctly, the cooler temps, especially while exporting (62C vs 99C), should definitely provide a performance boost: https://www.pugetsystems.com/labs/articles/Impact-of-Temperature-on-Intel-CPU-Performance-606/
As an aside, I built this computer in August/September of 2017. Rather than the 7700k, should I have gone with something in the same price point like the 5820k which has 6 cores?
Andrew
Votes
Translate
Translate
Report
Report
Guide ,
Hi Andrew. My pc days are long over. I'm a Mac man. I can't comment on mobs without researching them first but as a general rule of my own thumb, "the more cores the merrier"...
The 1050 will serve you well until Nvidia drops a few new model next year.
Look for CUDA cores before purchasing. Once again that rule of thumb applies. The more Cuda cores the better.
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
There are several good places to check before choosing parts ... the three supplies I mention all have an occasional presence by staffers on the Hardware forum, and their sites give good info on the parts they do recommend.
Where the 'local' geeks hang ...
Hardware Forum ... https://forums.adobe.com/community/premiere/hardware_forum
Several great video-post computer builder's shops ...
Puget Systems ...
https://www.pugetsystems.com/all_news.php
Safe Harbor Computing ...
Products for video and post professionals - Safe Harbor 800-544-6599 - Buy Online
And ADK ...
ADK Video Editing | 859-635-5762 | Professional Video NLE Workstations, Pro Video Gear and Video Sof...
There are very few of the CPU's out at any one time they each feel are particularly suited for video post. So ... you'll see the ones at various price points they recommend for different types of post work.
Puget has a great article and info ... more cores up to 10, ​fast​ cores, above 3.8Ghz to over 4.0 if possible, with up to 10GB of very fast RAM per core as the starting point. Then match a GPU so it will actually get used. That sort of thing.
Neil
Votes
Translate
Translate
Report
Report
