3 Replies Latest reply on Oct 26, 2018 10:25 AM by DigitalSpatula
    Settings for smooth slow motion on Premiere
    lucyusr22212740 Level 1
      Hi everyone,
      I am editing 50fps footage to be exported as 25fps. Some shots need to be in slow motion. So I just slowed them down by 50% (optical flow)
      and they look alright.
      I was wondering if this method is good. I've read somewhere that you actually need to set the whole sequence as 25fps, throw the 50fps footage there
      and then do the final export at 25fps. Isn't this the same as just setting at 25 fps ONLY when you export?
        • 1. Re: Settings for smooth slow motion on Premiere
          DigitalSpatula Adobe Community Professional
          Hi Lucy
          In general you want your sequence to be the framerate you want to output. Let's say your desired output is 25, then you male a sequence with that framerate. When you drag footage that's 50 in, it will look 25. Then you can change the duration to 200% and it will look smooth. The other option is to reinterpret the footage in the project window from 50 to 25, then when you drop it in your 25fps timeline, it will be half as fast and be quite smooth. You can even duplicate your footage in the project window and have have one at 50 and one at 25 (slow mo).
          Hope this helps,
          Steve
          • 2. Re: Settings for smooth slow motion on Premiere
            Hi Steve
            I have been editing on a 50fps sequence and the edit is pretty much done. If I set the sequence to 25fps now, will the edit stay intact?
            Also, why set the duration to 200%? Shouldnt it be like 50% for slow mo?
            • 3. Re: Settings for smooth slow motion on Premiere
              You can make a new 25fps sequence and copy and paste the entire edit into the new sequence and everything will be the same. I always preserve my original sequence as a backup.
              You are right about the 50%. Some apps use 50% for length some use the percentage for speed. PrP and AE use percentages opposite form each other.
              Steve
