1 Reply Latest reply on Oct 26, 2018 9:18 PM by osato_reg
    InDesign script to execute "Go To Selected Marker" on the Index panel
    osato_reg Level 1
      How do I execute "Go To Selected Marker" on the Index panel using a script?
      I want to write a script that generates a small text frame next to each index marker with the index entry written in the text frame.
      Dim myDocument As InDesign.Document
      Dim myIndex As InDesign.Index
      Dim myPageReference As InDesign.PageReference
      For i = 1 To myInDesign.Documents.Count Step 1
      myDocument = myInDesign.Documents.Item(i)
      Dim pageRefCount As Integer = 0
      For j = 1 To myDocument.Indexes.Count
      myIndex = myDocument.Indexes.Item(j)
      For k = myIndex.AllTopics.Count To 1 Step -1
      myPageReference = myIndex.AllTopics.Item(k).PageReferences.Item(1)
      ' Go To myPageReferennce Marker
      ' Get the marker coordinates
      ' Create a text frame
      ' Enter the index entry in the text frame
      Next
      Next
      Next
      Thank you in advance.
      Tak
        • 1. Re: InDesign script to execute "Go To Selected Marker" on the Index panel
          osato_reg Level 1
          I was able to figure this out. Not well documented, but below is the code if anyone is interested.
          ' Dim myPage As InDesign.Page
          ' Dim myPageReference As InDesign.PageReference
          Dim myTextFrame As InDesign.TextFrame
          Dim myGeometricBounds(3) As Double
          Dim myInDexColor() As Integer = {0, 0, 90, 0}
          Dim myIndexTextColor() As Integer = {98, 66, 0, 0}
          myAddColor(myDocument, "IndexingColor", InDesign.idColorModel.idProcess, myInDexColor)
          myAddColor(myDocument, "IndexingTextColor", InDesign.idColorModel.idProcess, myIndexTextColor)
          If myIndex.AllTopics.Item(k).PageReferences.Count > 0 Then
          For iPageReference = 1 To myIndex.AllTopics.Item(k).PageReferences.Count
          myPageReference = myIndex.AllTopics.Item(k).PageReferences.Item(iPageReference)
          ' Set the geometric bounds based on the insertion point of the source text
          myGeometricBounds(0) = myPageReference.SourceText.InsertionPoints.Item(1).baseline
          myGeometricBounds(1) = myPageReference.SourceText.InsertionPoints.Item(1).horizontaloffset
          myGeometricBounds(2) = myPageReference.SourceText.InsertionPoints.Item(1).baseline + 4
          myGeometricBounds(3) = myPageReference.SourceText.InsertionPoints.Item(1).horizontaloffset + 150
          ' Create the text frame
          myPage = myPageReference.SourceText.ParentTextFrames.Item(1).ParentPage
          myTextFrame = myPage.TextFrames.Add()
          myTextFrame.GeometricBounds = myGeometricBounds
          myTextFrame.FillColor = myDocument.Colors.Item("IndexingColor")
          myTextFrame.FillTransparencySettings.BlendingSettings.Opacity = 70
          myTextFrame.StrokeColor = myDocument.Colors.Item("Black")
          myTextFrame.Contents = myPageReference.Parent.Name
          ' If the topic is a subtopic, make the textframe contents "topic : subtopic"
          ' Currently only supports two topic levels.
          If myPageReference.Parent.Parent.Name <> "" Then
          myTextFrame.Contents = myPageReference.Parent.Parent.Name & " : " & myTextFrame.Contents
          End If
          ' Set the text frame's font size and color
          myTextFrame.ParentStory.PointSize = 10
          myTextFrame.ParentStory.FillColor = myDocument.Colors.Item("IndexingTextColor")
          myTextFrame.Fit(InDesign.idFitOptions.idFrameToContent)
          ' Make the text frame a little bigger to give a margin on the right
          myGeometricBounds(3) = myTextFrame.GeometricBounds(3) + 2
          Next
          End If
          Next
          Next
          Next
