• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Using CFFILE Upload to Modify an Existing File
New Here ,
Jul 12, 2006 Jul 12, 2006
I am using to following code to modify an existing file on the server, but when I submit the code nothing happens on the server and the file does not get overwritten or modified. Could someone look at my code and see If I am missing anything?
Thanks, cfgator
CODE:
<cfif #FORM.hsmFileName# NEQ '' >
<!--- Modify Small Image files --->
<cffile
action="upload"
filefield="smImageFil"
destination="D:\www_root\qep\web\images\products\"
attributes="Normal"
nameconflict="overwrite">
<cfset oldPathAndName = #FORM.hsmFileName#>
<cfset arrPathAndName = ListToArray(oldPathAndName, '\')>
<cfset fileName = arrPathAndName[ArrayLen(arrPathAndName)]>
<!--- Rename the file to the product number --->
<cfset name1 = "D:\www_root\qep\web\images\products\" & #filename#>
<cfset name2 = "D:\www_root\qep\web\images\products\" & #form.prod_number# & "_" & "sm" & "." & "JPG">
<cffile action="rename"
source = "#name1#"
destination = "#name2#"
attributes = "Normal">
</cfif>
TOPICS
Advanced techniques
Views
254
Translate
Translate
Report
Report
Community guidelines
community guidelines
Explorer ,
on the destination attribute try adding the name of the file at the end of the directory path.
Votes
Translate
Translate
Report
Report
New Here ,
Jul 13, 2006 Jul 13, 2006
dpretlor,
How would I use the destination attribute to place the name of the file when there will be differnet files being modified and added when using this code?
cfgator
Votes
Translate
Translate
Report
Report
New Here ,
Jul 18, 2006 Jul 18, 2006
Let me add my form and see if this explains why I am not able to modify a file on the server?
<form name="admin_products" action="index.cfm?fuseaction=dsp_admin_products&subaction=mod&processAction=submitMod" method="post" enctype="multipart/form-data" >
<table>
<!--- Small Product Image File --->
<tr>
<td>
Small Product Image <font color="red"><b>*</b></font> : </td>
<td>
<input class="text" type="File" name="smImageFil" value="Browse..." size="30" tabindex="9" onBlur="return setValue(this, hsmFileName);">
<input type="hidden" name="hsmFileName" value=""> </td>
</tr>
<tr>
<div align="center">
<input type="Submit" name="submit" value=" Modify " tabindex="7">
<input type="Reset" name="reset" value=" Reset ! " tabindex="8">
<input type="Hidden" name="processAction" value="submitMod">
</div> </td>
</tr>
</table>
</form>
<script language="JavaScript">
function setValue(obj1, obj2)
obj2.value = obj1.value;
return true;
</script>
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
cfgators,
One thing I see that I would change is where you set your variables. You shouldn't use & signs.
Your name1 ends up being D:\www_root\qep\web\images\products\&filename while your name2 ends up being D:\www_root\qep\web\images\products\&prodnumber&_&sm&.&jpg
If you take out the & signs and the spaces your file name should work and your file should write correctly. Like so...
<cfset name1 = "D:\www_root\qep\web\images\products\#filename#">
<cfset name2 = "D:\www_root\qep\web\images\products\#form.prod_number#_sm.JPG">
Votes
Translate
Translate
Report
Report
Resources
Documentation
