1 Reply Latest reply: Jan 22, 2008 12:43 PM by kglad RSS
    Flash Pop-up Window
    YTCollege Community Member
      I have been asked to do a small pop-up window in Flash that contains a background pic and FLV. When I finish creating the flash window, I am to give it to our html web designer. He will put a link on an html page to open the flash pop-up window. My question is, to make this a popup window (declare the size, position, etc...) do I put the code in the flash file, or does the web designer put it in the html file? Thanks!!
        • 1. Re: Flash Pop-up Window
          kglad CommunityMVP
          if your flash is the popup file, the code for that popups size and position will be done by the web designer. if your flash contains a link that will generate a popup window, the coding will be done by you.
