1 Reply Latest reply on Jan 28, 2008 9:16 AM by Carmen-Luisa_Ghita
    Errors exist in required project(s):
    jeffcg2 Level 1
      What is this saying? Where do I look to fix this?
      I had a project running then added a file. This message pops up immediately in a popup "Errors in Workspace".
      There is also the question "Proceed with launch?"
      I have the same problem if I just try to manually add a project instead of using a wizard.
        • 1. Re: Errors exist in required project(s):
          Carmen-Luisa_Ghita
          Hi Jeff,
          please see below...
          This window usually appears when there are compilation errors in the project you are trying to run or in any of the projects related to the one you are trying to run. By solving the errors the window will not appear anymore.
          Can you please explain what you mean exactly by "manually add a project instead of using a wizard"?
          Please give detailed steps.
          Thank you,
          Carmen
