2 Replies Latest reply on Feb 5, 2019 1:17 PM by John Ratard
    Black Home Screen on Adobe Pr Pro CC 2019...
    EMJAYWLZ Level 1
      Greetings folks,
      Has anyone experienced this problem since updating to Pr Pro CC 2019?
      I've seen similar things like this in the forums for older versions of Pr, but those fixes do not seem to apply here.
      Just hours ago my "home" screen in Adobe Pr Pro CC 2019 open up completely black.  It was working earlier in the day.
      I did an uninstall, reinstall, and restart, and have also opened Pr while holding option to clear preferences, but no luck.
      I've used an old trick for earlier versions of the app, where you rename the "opm.db" file from inside the OOBE folder and restart but no luck.
      I also noticed this problem on the home screen when I opened up Adobe Photoshop CC 2019.  Not sure what to make of it.
      I can still open project and work with them but it seems odd this has randomly happened and would like to get it back to normal.
      Anyone out there have a fix?
      My systems specs:
      macOS High Sierra  version 10.13.6 (17G65)
      Mac Pro (Mid 2010)
      Memory: 17GB 1066 Mhz DDR3
      Processor: 2 x 3.46 GHz 6-Core Intel Xeon
      Graphics ATI Radeon HD 5770 1024 MB
      *I recently swapped the video card out from a Quadro 4000 for Mac 2GB video card.  The ATI is a step down in RAM but it's stable for some reason.  Even with drivers, the nVidia Quadro just kept having kernel panics and boot loops.  Sometime stable, other times random. So far the ATI experience has been very pleasurable.
      Thank for your time folks!
      Best ~ MJW
        • 1. Re: Black Home Screen on Adobe Pr Pro CC 2019...
          Kevin-Monahan Adobe Employee
          MJW,
          Your system is underpowered for current versions of Premiere Pro. You may want to downgrade to an earlier version. Hope that info helps.
          Kevin
          • 2. Re: Black Home Screen on Adobe Pr Pro CC 2019...
            John Ratard Level 1
            I have two problems with my Version 13.0.2 (build 38), one being perhaps related to this post.
            1. I may be having a similar problem with my home page that is not black but blue with the previous projects that used to be revealed but now no longer showing with a revolving partly blue wheel in the center.  I can bypass this by opening projects one by one that I can edit.
            2.  I cannot scroll the various character sets in the Legacy Title Properties Font Family.
            My system is as follows:
            Windows 10 Pro
            Hex Core i7 - 3930K CPU @ 3.20GHz
            RAM 32 GB
            64-bit OS No Pen or Touch for PA249Q display
            4 1TB 7200rpm in 2 RAID config, 3 SSD, I PNY USB3  flash, drives for capacity/cost compromise.
            What do you recommend?
