1 Reply Latest reply on Jan 24, 2008 8:53 AM by reicolneat
    Robohelp Crashes when I cut and past
    R-V
      Does anyone have a solution to this problem which has cropped up over the past couple of days?
      I am using RH6. When I try to cut and paste text, or copy - all standard word-style functions, RH crashes. I have trued the usual tricks to repar my corrup[ed database, but the problem will not go away. I recently tried to import a word document, which I suspect has cause the problem. Now, how do I fix this?
        • 1. Re: Robohelp Crashes when I cut and past
          reicolneat
          I'm not sure exactly what you're trying to copy and paste.
          I've found that when I try to copy and paste links that appear in a list in the WYSIWYG editor, RH crashes. If I do the copy and paste in the TrueCode editor, it works just fine. If your topics are in a list, make sure you add the necessary HTML ( <ul> <li> </li> </ul> ).
          If you're trying to copy and paste an entire topic, this won't work for you.
