• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
LR spot removal
New Here ,
Nov 04, 2018 Nov 04, 2018
Hi !
Since we have updated LR, we are not in the possibbility to use the spot removal option, the system blocks completely.
Is there any way to solve this problem, or could we "undo" the update?
BR
Nicky
Views
606
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Nov 04, 2018 Nov 04, 2018
Turn off the GPU acceleration in LR. Go to Preferences, then click on the Performance tab, then uncheck "Use Graphics Processor".
If this doesn't help, then you have encountered a known deficiency in LR, if you do a lot of brushing and/or a lot of spot healing, Lightroom will slow down and appear to come to a stop for a few seconds. Some things you can try:
  1. Do the brushing and/or spot healing as the next to last step in the editing process; and the last step is to turn on transforms and lens corre
Votes
Translate
Translate
LEGEND ,
Working fine here. So please state the Exact problem you are having. Saying it Doesn't work doesn't mean much.
Open it and take a screen shot of what you are seeing.
Votes
Translate
Translate
Report
Report
New Here ,
The system keeps thinking, and doesn't react at all. Not much of a screenshot I can do. Sometimes the screen gets black, sometimes the computer blocks completely.
If the spot removal is still on, and the computer "wakes up", you see lines and stripes all over the picture, where the mouse has been moved to.
Votes
Translate
Translate
Report
Report
LEGEND ,
You have a hardware problem.
First thing to do is turn off the GPU option in LR. LR Preferences, Performance tab, un-check use the GPU.
Then restart LR and your system and test.
If that doesn't help then there is some other hardware fault that is causing the system to Lock UP (what I think your are referring to as block).
Could be an overheating issue. Try blowing out the dust in your system and test.
Votes
Translate
Translate
Report
Report
New Here ,
so, this problem occurs on 2 different computers...?
Votes
Translate
Translate
Report
Report
New Here ,
Hi again,
no overheating for sure
Would you mind explaining me how to do so?
Votes
Translate
Translate
Report
Report
LEGEND ,
  1. Do the brushing and/or spot healing as the next to last step in the editing process; and the last step is to turn on transforms and lens corrections
  2. Do the brushing and/or spot healing in Photoshop
  3. Get a faster CPU
Votes
Translate
Translate
Report
Report
New Here ,
Yesssss !!!!
Unbelieveable, have been in trouble for such a long time, and now in a few vclicks this issue is gone !
Hurray !
Thanks a LOT from Belgium 🙂
Could this also be an issue in PS?
Nicky
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
Unlikely its the same issue.
Votes
Translate
Translate
Report
Report
LEGEND ,
... the system blocks completely.
Describe this in detail.
Votes
Translate
Translate
Report
Report
