2 Replies Latest reply on Jul 3, 2006 9:02 AM by Newsgroup_User
    How can I give this effect to the Picture
    faisy_master
      Hello all,
      I want to give this special effect in the picture but I can't figure that how will I do it ...
      See the background picture in this site {of herbs, butterflies blah blah}
      http://www.mtv.nl/index.php
      any idea that how can I do it in the fireworks or any other software.
        • 1. Re: How can I give this effect to the Picture
          ageofem Level 1
          Hey fairy , most of the stuff here , the butterflies and fluide shapes were probably created with brushes in ps2, but in fireworks we can use vectors. Drawing these vectors, require much time, especially for the butterflies and swans. Then to create the transparent effect , the objects opacity level on each layer were reduced , ( if some of the objects overlapped , they were also punched ). These shapes were probably replicated in some areas, an so forth
          ---- As for the curvy lines , a simple circle could achieve a similar effect using the reshape area tool ( and you can add more shapes around it ). http://www.deviantart.com/deviation/32599128/ << view this work for example. You could also draw them using the pen tool if you want. Or you could also use fonts for these , take for example a script font . Take a look at this > http://www.deviantart.com/view/29003638/ <<< on the top part where you see the two yellow glowing circles, you can easily spot that a script font was used ( I think I used letters , G , H , and S mostly )
          ---- In fireworks 8 , you can use convert marquee to paths, and select a picture you choose and convert it to paths.
          quote:
          Originally posted by: faisy_master
          Hello all,
          • 2. Re: How can I give this effect to the Picture
            Level 7
            You might also be able to find the various shapes you want through some
            online free resources, such as Microsoft Clip Art. I found 34 pages of
            butterflies by doing a quick search
            Jim Babbage - .:Community MX:. & .:Adobe Community Expert:.
            Extending Knowledge, Daily
            http://www.communityMX.com/
            CommunityMX - Free Resources:
            http://www.communitymx.com/free.cfm
            .:Adobe Community Expert for Fireworks:.
            news://forums.macromedia.com/macromedia.fireworks
            news://forums.macromedia.com/macromedia.dreamweaver
            > Hello all,
            > will I do it ...
            > Thanks
