• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Lightroom developer mode does not work at all.
New Here ,
Nov 04, 2018 Nov 04, 2018
I tried to work with lightroom developer mode but when I select an image it still stays on the grey screen instead of showing the image I want to work on. I tried disabling my gpu but this did not change anything at all so I re enabled them again. I am trying to figure out what the problem is but all I can figure out is that maybe it is because I started the trial first to see how it works.
Views
1.5K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Guest
I have the exact same problem. I also tried adding the config.lua file, updating GPU drivers, changing the monitor profile, different file formats and much more.
Selecting the picture in Library:
View in Develop:
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
This might be caused by a defective monitor profile.
Try setting the monitor profile to sRGB (use Adobe RGB if you have a wide gamut monitor).
Restart Ligthroom after changing the monitor profile for the change to take effect.
See http://www.lightroomqueen.com/articles-page/how-do-i-change-my-monitor-profile-to-check-whether-its-...
If this fixes the problem, you should ideally calibrate the monitor with a hardware calibrator. This will create a new monitor profile that accurately describes your monitor.
Votes
Translate
Translate
Report
Report
