I have about a dozen Windows 10 systems that have stated getting a C:\Program Files\WindowsApps\AcrobatNotificationClient error. The error is "Windows cannot access the specified device, path or file. You may not have appropriate permissions to access the item.
We do not push updates to Adobe products.
Any idea what may be causing this error?
THX!
Hi mortonpc4,
As per the issue description mentioned above, users are getting Acrobat notification client error on Win 10 machines, is that correct?
Could you confirm the dot version of Acrobat installed on the machine? You may refer to the steps given in this link on how to check the version in Acrobat: Identify the product and its version for Acrobat and Reader DC
Let us know if you need any help.
Shivam
Hello!
The version we are running into this on is Acrobat 19.008.20080 running on Windows 10 Pro 10.0.15063 and another on Win 10 Pro 10.0.16299
Cheers!
Patrick.
Hi Patrick,
Thanks for the info. Could you try rebooting the machine once if you haven't already and check if users are still receiving the error?
If yes, try repairing Acrobat using "Repair installation" option under Help menu, reboot the machine after repair and check.
Shivam
Greetings!
Unfortunately the suggestions you send did not work.
Cheers!
Patrick.
Hi Patrick,
Could you try replicating the issue in an admin account by clicking Start > Settings > Accounts > Family & other users, and check if the issue persists?
If yes, remove Acrobat on one of the machines using cleaner tool which you can download from here: Download Adobe Reader and Acrobat Cleaner Tool - Adobe Labs
Reboot the machine.
Install Acrobat from here: Download Acrobat DC installer for Enterprise term or VIP license and check.
-Shivam
Greetings!
I will reach out to an affected user and see if they are able to do this.
I will let you know what happens ASAP.
Cheers!
Patrick.
Hey Patrick,
I think I am having the same issue. Have you found a fix for this?
We have been experiencing the same on a handful of machines and have never been able to figure this out.
Have you reviewed whether the Acrobat Notification Client communications can occur, both In & Out, in the effected machines?
You'd need to review the firewall settings
