4 Replies Latest reply on Nov 15, 2018 8:56 AM by r.correa
    After the crash, the project does not work
    evgeny hive
      Hello!
      I am doing a template project with Adjustment Layers (for videostocks).
      Periodically, when I want to remove or undo an action (CTRL+Z) for Adjustment Layers, Premiere Pro is crashes.
      Earlier, when I was working in cc.2018, it was enough just to open the project and continue with the last save point, but on cc.2019 a new problem came up.
      A project that was saved before the crash - when opened does not work.
      The program interface works, but in the program panel I see only a black screen.
      It lasts indefinitely and when try to close a project - Premiere Pro freezes. Helps only the task manager.
      I completely cleaned the contents of the cache folders but it did not help.
      But I found a workaround that works - need to create a new project and import into it an old project that has not worked before.
      After that, the project works fine.
      Is there a more convenient solution?
      Operating System: Windows 10 Pro, 64-bit
      Processor: AMD Ryzen Threadripper 1950X 16-Core Processor 3.40 GHz
      Installed memory (RAM): 32.0 GB
      Video card:  GeForce GTX 1080Ti
