I'm really at a loss. I've been researching all day... Got the SDK setup and working, wrote my first filter. Had a ton of trouble figuring out how on earth the UI hooks were working in the C++ SDK. Then when I realized I needed to use CEP to create my UI modal, I started down that rabbit hole.
What I've done:
- I tried the Eclipse path, but it was so out-of-date, I just started trying to write my own extension by copying one of the samples.
- Then I learned about the brackets extension, and I installed brackets and the Extension Builder plugin
- Created an extension project for Photoshop with my desired bundle id
- Turned on debugging
- triple-checked the registry, looks good
- restarted computer 3 times
- Tried opening photoshop, my extension is not in Window/Extensions
- Since debugging wasn't working, tried signing and installing the extension.
- signed successfully
- installed successfully
- still doesn't appear in window/extensions
Details:
Windows 10 (I've noticed most of the guides are for Mac... I wonder if Windows is less tested?)
Photoshop CC 2018
XML:
<?xml version="1.0" encoding="UTF-8"?>
<ExtensionManifest Version="8.0" ExtensionBundleId="studio.moonsicle.ColorSwapperUI" ExtensionBundleVersion="1.0.0"
ExtensionBundleName="ColorSwapperUI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<ExtensionList>
<Extension Id="studio.moonsicle.ColorSwapperUI" Version="1.0" />
</ExtensionList>
<ExecutionEnvironment>
<HostList>
<!-- Photoshop - I don't need to support anything below 2018, and I don't want my extension to fail next year -->
<Host Name="PHXS" Version="[19.0,99.0]" />
<Host Name="PHSP" Version="[19.0,99.0]" />
</HostList>
<LocaleList>
<Locale Code="All" />
</LocaleList>
<RequiredRuntimeList>
<RequiredRuntime Name="CSXS" Version="8.0" />
</RequiredRuntimeList>
</ExecutionEnvironment>
<DispatchInfoList>
<Extension Id="studio.moonsicle.ColorSwapperUI">
<DispatchInfo >
<Resources>
<MainPath>./index.html</MainPath>
<ScriptPath>./jsx/hostscript.jsx</ScriptPath>
</Resources>
<Lifecycle>
<AutoVisible>true</AutoVisible>
</Lifecycle>
<UI>
<Type>Panel</Type>
<Menu>ColorSwapperUI</Menu>
<Geometry>
<Size>
<Height>300</Height>
<Width>300</Width>
</Size>
</Geometry>
<Icons>
<Icon Type="Normal">./icons/iconNormal.png</Icon>
<Icon Type="RollOver">./icons/iconRollover.png</Icon>
<Icon Type="Disabled">./icons/iconDisabled.png</Icon>
<Icon Type="DarkNormal">./icons/iconDarkNormal.png</Icon>
<Icon Type="DarkRollOver">./icons/iconDarkRollover.png</Icon>
</Icons>
</UI>
</DispatchInfo>
</Extension>
</DispatchInfoList>
</ExtensionManifest>
try with this
...<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<ExtensionManifest ExtensionBundleId="studio.moonsicle.ColorSwapperUI" ExtensionBundleName="studio.moonsicle.ColorSwapperUI" ExtensionBundleVersion="0.3.0" Version="4.0">
<ExtensionList>
<Extension Id="studio.moonsicle.ColorSwapperUI" Version="0.3.0"/>
</ExtensionList>
<HostList>
<Host Name="PHXS" Version="[14.0,19.9]" />
<Host Name="PHSP" Version="[14.0,19.9]" />
</HostList>
Moving to Photoshop Scripting
See if so resolve
replace
this
with this
I should have included that in my question. I have tried:
14.0,99.0 (what the simpledissolve sample uses)
19.0,19.9
14.0,19.9
14.0,99.0
Additionally, my project directory is currently located in the brackets default directory for CEP projects:
C:/Users/[me]/AppData/Roaming/Adobe/CEP/extensions
However I have also tried
C:/Program Files/Common Files/Adobe/CEP/extensions
C:/Program Files (x86)/Common Files/Adobe/CEP/extensions
try with this
<ExtensionList>
</ExtensionList>
<HostList>
</HostList>
<LocaleList>
<Locale Code="All"/>
</LocaleList>
<RequiredRuntime Name="CSXS" Version="4.0"/>
<DispatchInfoList>
<DispatchInfo>
<Resources>
</Resources>
<Lifecycle>
</Lifecycle>
<UI>
<Type>Panel</Type>
<Geometry>
<Size>
<Width>300</Width>
</Size>
</Geometry>
<Icons>
</Icons>
</UI>
</DispatchInfo>
</Extension>
</DispatchInfoList>
That works! I'm going to accept your answer, but... why didn't CSXS version 8.0 work for CC 2018?
NOTE:
- I didn't need to change photoshop version to [14.0,19.9] I left it at [19.0,99.0]
- All I changed was the ExtensionManifest and RequiredRuntime to 4.0
@geppettol66959005
Please see my question above. CC2018 should support CEP 8.0, which I believe is CSCX 8.0?
I could not tell you
I only know that in the past I had a problem similar to yours
and I solved this way.
