Hello,
I'm having a problem with using Adobe Captivate 3 and Adobe Flash CS3 in tandem to get my Captivate project in a file format accepted by online video sharing sites such as YouTube. Since Captivate 3 does not have an option to export to .avi or any other accepted movie file format, I thought that I would export the Captivate project to Flash, and then export it to the avi file format through Flash. However, whenever I select "File>Export>Project To>Flash CS3," I get the following error in Flash:
quote:
The import did not finish because an unknown error occurred
I could not find any resources that pertained to my particular problem. I am using Windows Vista Ultimate 64-bit, with a different directory structure than XP. In the Adobe Developer Center article " Exporting your Adobe Captivate project to Flash," it references a certain "RDMFISTUB.DLL" file that I cannot locate on my system. Could this problem be caused by incompatibilities with Vista?
My end goal is to post a Captivate project comprised of mostly full-motion recording to YouTube. If there is another way to do this that doesn't involve installing any 3rd-party software, I'm open to that as well.
Thank you
Thanks for the help, Larry. Whatever the problem was with Captivate and Flash, it's partially fixed. Now, if I have the "unknown error" problem, I open and close Captivate and Flash a couple times, which does the trick. Unfortunately, I have a new problem with Flash.
When I have a Captivate project that is *all* full-motion recordings (with microphone audio recordings) and I export it to Flash and then export it to .mov (my new format of choice), I get the full-motion recordings, with no sound. This lack of sound is a problem, but not a show-stopper.The much bigger obstacle is that when I export a Captivate project that incorporates full-motion recordings with static slides displaying a text caption to Flash and then to .mov, I lose the full-motion recordings: they are replaced with a blank white or black screen (whatever the background color is set to be). The audio is gone too. I don't know what is causing this, but I would really appreciate any help you could lend me concerning this.Once again, thank you for your previous assistance,Copy link to clipboard
quote:I don't have a solution - maybe someone else here does - but would offer an observation ...
quote:
Originally posted by: CatBandit
when the project is published to SWF/HTM, each full-motion slide is published as a separate SWF file. Would it be possible to publish the project, then try to bring that SWF back into Captivate as an animation? It's late here and I'm getting into fuzzy-thinking time, so if that doesn't make sense, it wouldn't surprise me.
