1 Reply Latest reply on Jan 24, 2008 11:13 PM by ThinkInk
    Publish PDF won't overwrite current file
    msisson
      I'm trying to simply replace a PDF file on a website with an updated version. Since the filename is part of the navigation I want to keep it the same. Contribute doesn't ask if I want to replace the file, it simple creates a new one on the server with the base file name plus 000, 001, 002, etc. How do I get Contribute to overwrite the file on the server?
        • 1. Re: Publish PDF won't overwrite current file
          ThinkInk Level 2
          You will have to get your administrator to give you the rights to delete files. When you can delete them, you can also overwrite.
          If you are the administrator:
          1. in the menu go to Edit, Administer my websites
          2. go to Users and roles, pick you role, click Edit role settings
          3. go to File/folder access
          4. check the bock that allows you to delete files.
