With the help of someone else, I was finally able to change the drop cap by replacing the information directly in the character style rather in the paragraph in Sigil. I removed the information between brackets and replaced with the following:
font-family:Textura, serif;
line-height: -38%;
height:0.95em;
font-size: 420%;
margin-right: 0.075em;
margin-top: -0.15em;
float:left;font-style:normal;
font-weight:normal;
I should explain a bit more. Drop caps were created in the print version in CC 2018. When exported to ePub 3, they disappear. With a little tweaking I can get them to show up in the iBook but above the whole paragraph. Nothing seems to make a difference. I then tried creating them manually in their own text box but it will not get in the right place either.
I really don't know anything about CSS and HTML but was giving it a try.
Try this code with an intro paragraph with a .paraintro class for a multi-line dropcap. You will have to adjust the font size and other properties for your own project, and leave out the float if you don't need drop-cap text wrap. Or apply to the dropcap class.
.paraintro::first-letter {
color: #903;
float: left;
font-family: Georgia;
font-size: 93px;
margin-top: 8px;
padding-right: 8px;
margin-left: -8px;
Thanks, Rayek. I tried just putting this in a few places and taking some out (with Textura substituted for font) but get the "not a well formed XML" message.
Here is what the code looks like currently:
<p class=“_st-Paragraph”><span class=“Drop-Cap”>I</span>was in a place I never dreamed would be.
Drop-Cap is the name of character style.
How and where should I put your code?
Have you tried this?
<p class=“_st-Paragraph”><span class=“Drop-Cap” style="color:#903;float:left;font-family:Textura;font-size:93px;margin-top:8px;padding-right:8px;margin-left:-8px;">I</span>was in a place I never dreamed would be.</p>
Thanks, rayek. This worked. Thanks!
The leading on the drop cap grabs an extra line in text wrap. I have the character leading set to 0 in the Character style but it is obviously a lot larger than this.
Spoke too soon. The drop cap does not show up in the iBook.
line-height: -38%;
height:0.95em;
font-size: 420%;
font-weight:normal;
