hi all,
within minutes (literally less than five minutes) working in the new Audition CC2019 I'm finding problems.
The "duplicate track" function doesn't work properly. Let's say that you duplicate track 1 (with it's particular bus routing setup or whatever) to create track 2. Now if you mute track 1, track 2 will also mute (even though you have not actually opted to mute track 2 and the tracks mute button does not show as activated). Or if you solo track 1, then track 2 will also play through the mixer as if soloed.
Thus rendering the duplicate track function absolutely f*cking useless.
Anyone else replicating this same problem, I'm assuming it's not just me?
Yes there is a problem with it, but it's not quite as you've reported it - well not here, anyway. If you move, say, a duplicated clip slightly whilst it's soloed, it will reproduce up to the point where the original stops, and then won't play any further. If it's moved completely out of range, it won't play at all.
However you look at it, it doesn't appear to be working correctly. I'll report it directly as a bug, with reference to this thread.
[update: reported as a bug]
Hi Steve, yes that possibly makes sense with what I've experienced. The bottom line is that the duplicate track function is unusable whilst this problem persists - thanks for reporting it as a bug
cheers
