This is a tricky problem but someone has probably seen it before.
I have one slide with four buttons and four smart shapes that contains information. The idea is this:
This is what I have done:
Here's the AA if you want to check it.
I hope someone can help me.
Btw, I'm using Mac, latest OS and latest Captivate 11.0.1.226.
This is much easier with a multistate object. I did publish two posts, one for a non-responsive project and one for a responsive project where I compare the workflows. It has also a conditional appearance of a Next button. This is the one for a non-responsive project:
Force Clicking Hotspots: Comparison 2 Workflows - eLearning
Is the Visited state an InBuilt state or a custom state? You should use a custom state.
As for the Hide/Show workflow, you will read in the blog post that I recommend to use
...Copy link to clipboard
As for the Hide/Show workflow, you will read in the blog post that I recommend to use grouping for the info boxes. That way you get rid of two commands, because you'll need only:
HIde Group
Show info.
SORRY. Those were recommendations, but I see you jump to the same slide, That will NOT replay the On Enter action at all. I explained that extensively in this blog post. You need to RE-ENTER the slide to have that action run.
Thank you Lilybiri. I thought so. Jump To Slide does not work at all in this case. However, I followed your recommendation and used Multistage Objects for the info box, it's so easy to use but powerful. And combined with some advanced actions. Now it works perfect.
The Jump to Slide is working, but when used to the same slide as the current slide it is just going to the first frame of that slide which is logical. To have the On Enter action also done, you should have to jump to at least one frame before the first frame of this slide. That is what I explained in that blog post.
Ah, thank you for the clarification.
