• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
dvd not play on windows 10 laptop
Participant ,
Nov 08, 2018 Nov 08, 2018
dvd created in encore CS6 will not play on a windows 10 latop?
Views
469
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Do any DVDs play? What version of Windows 10 do you have?
Votes
Translate
Translate
Report
Report
Participant ,
Nov 09, 2018 Nov 09, 2018
Not sure I'd have to check with the client
Votes
Translate
Translate
Report
Report
Participant ,
Yes, commercial dvds play ok
Votes
Translate
Translate
Report
Report
Community Expert ,
DVDs produced with Encore CS6 will play in Windows 10 PCs, but only if they have the media options installed. If they can play commercial DVDs, it should be okay.
You can have a problem with a single disk out of a batch (bad media; failing burner) or an authoring problem (very disk will fail, but perhaps only on some platforms (works on player hooked to TV, not on PC). And this is always difficult when you're trying to get the client to troubleshoot.
Can you play a copy of the disk on a PC? On a player hooked to a TV?
If you believe you have a well-authored disk, just send another copy. But often you can't know that.
My quality control (when I was producing more disks than the very few I do now) included 1) software players (build to folder or image and play on PC; my favorite then was Total Media Theater; now PowerDVD - others, e.g. VLC often failed to correctly handle slideshows or such); 2) burn rewriteable and test on computer; then 3) test rewriteable on multiple DVD/BD players and TVs; 4) burn to DVD-R and same tests. If it was for a single client, I'd test the single disk going out more than if it was multiple clients. My best test (for finding oddities in Encore's processing) was my son's portable DVD player. If it would play it, anything would.
Votes
Translate
Translate
Report
Report
Participant ,
Thanks for your detailed response Stan.
Turns out it is an older laptop 3-4 years (this was all communicated via the clients mother -hence some confusion!).
The dvd sent out has since been played on an old dvd player and it works fine. The dvd played OK on my pc (windows 7 professional ) and I tested on my dvd player which worked fine.
She is now going to buy a dvd player!
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
DVD burner/player probably needs firmware update.
Votes
Translate
Translate
Report
Report
