Hello!
I'm trying to edit a script that creates a JPEG copy of the document in a subfolder but I could not fix this problem:
How to save only the document name?
Script:
var subfolder = "BackupFolder";
if (app.documents.length > 0) {
var thedoc = app.activeDocument;
var docName = thedoc.name;
var basename = docName;
if (docName.indexOf(".") != -1)
basename = docName.match(/(.*)\.[^\.]+$/)[1]
var docPath = "~/Desktop";
try {
docPath = thedoc.path;
} catch (e) {}
var jpegOptions = new JPEGSaveOptions();
jpegOptions.quality = 9;
jpegOptions.embedColorProfile = true;
jpegOptions.matte = MatteType.NONE;
//save tif as a copy:
if (!Folder(docPath + "/" + subfolder).exists) Folder(docPath + "/" + subfolder).create();
var saveFile = docPath + '/' + subfolder + '/' + thedoc.name +'.jpg';
if (File(saveFile).exists)
saveFile = incrementFile(saveFile);
thedoc.saveAs(new File(saveFile), jpegOptions, true);
function incrementFile(pathToFile) {
var saveSufixLength = 2,
suffix = zeroPad(0, saveSufixLength),
newPathToFile = pathToFile,
suffixInteger, folder, fileName, extension;
while (File(newPathToFile).exists) {
suffixInteger = parseInt(suffix, 10);
suffixInteger += 1;
suffix = zeroPad(suffixInteger, saveSufixLength);
folder = File(pathToFile).path;
fileName = File(pathToFile).name.substring(0, File(pathToFile).name.lastIndexOf("."));
extension = File(pathToFile).name.substring(File(pathToFile).name.lastIndexOf(".") + 1, File(pathToFile).name.length);
newPathToFile = folder + "/" + fileName + "_" + suffix + "." + extension;
return newPathToFile;
function zeroPad(num, digit) {
var tmp = num.toString();
while (tmp.length < digit) {
tmp = "0" + tmp;
return tmp;
(untestet) but it seems
should be:
var saveFile = docPath + '/' + subfolder + '/' + basename +'.jpg';
should be:
Perfect! Thank you pixxxel schubser.
