32 Replies Latest reply on Jun 23, 2008 4:45 PM by Darren McNally - Adobe
    Flash 9: Failed to Install tn_19166 - can't get it to install
    cgmoore64
      I've tried to install Flash 9 a number of times but continue to get the same error message:
      Failed to install. For Troubleshooting please see: http://www.adobe.com/go/tn_19166
      See my system info below. I also tried everything under tn_19166 and the info in the forum posted at the bottom of this post.
      Any suggestions on how to resolve the issue?
      Chris
      SYSTEM INFO
      OS Name Microsoft Windows XP Professional
      Version 5.1.2600 Service Pack 2 Build 2600
      System Model Dell Inspiron 8500
      Processor x86 Family 15 Model 2 Stepping 9 GenuineIntel ~2193 Mhz
      BIOS Version/Date Dell Computer Corporation A06, 7/12/2004
      SMBIOS Version 2.3
      Hardware Abstraction Layer Version = "5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)"
      Total Physical Memory 512.00 MB
      Available Physical Memory 143.99 MB
      Total Virtual Memory 2.00 GB
      Available Virtual Memory 1.96 GB
      ACTIONS TRIED
      01/15/2008 11:55:34 PM
      Reply | Quote | Top | Bottom
      Download the uninstaller for Flash Player from "How to uninstall the Adobe Flash Player plug-in and ActiveX control"
      http://www.adobe.com/go/tn_14157
      Quit ALL running applications, including all Internet Explorer or other browser windows, AOL Instant Messenger, Yahoo Messenger, MSN Messenger, or other Messengers. Check the Windows system tray carefully to make certain no applications which might possibly use Flash Player are still in memory.
      Install the new Flash Player from here:
      www.adobe.com/go/getflashplayer
      Check to see if Flash Player is installed:
      http://www.macromedia.com/software/flash/about/
      Regards,
      Darren J. McNally,
      Technical Support Engineer, Adobe
      Flash/Flash Player Support
        • 1. Re: Flash 9: Failed to Install tn_19166 - can't get it to install
          aligator347
          I would like to hear a response because I am having a similar problem.
          • 2. Re: Flash 9: Failed to Install tn_19166 - can't get it to install
            ob1_48127@yahoo.com
            I too, would like to hear a response as I did the suggested uninstall procedure the same as above. I am on a Windows Me platform and the install process just sits. I get the box for the video to play in but no video,so I assume the install is not successful.
            • 3. Re: Flash 9: Failed to Install tn_19166 - can't get it to install
              IdidntWantAccount
              i HAD Same problem ....... wat i did was go to contoll panel / click ADD or remove programs
              / then i delte all types of flash player / it wont install if ur like say , using it or sumtin / then i installed it and it work
              ... i have an xp compaq
              • 4. Re: Flash 9: Failed to Install tn_19166 - can't get it to install
                cgmoore64 Level 1
                Yep, already did all dat. Didn't wrk.
                • 5. Re: Flash 9: Failed to Install tn_19166 - can't get it to install
                  kennydont
                  I am having the same problem! It is driving me nuts. I have done everything this website has told me to. my mother-in-law had the same problem and can't remember how she fixed it, so if someone could figure out this mystery it would be MUCH APPRECIATED!!
                  • 6. Re: Flash 9: Failed to Install tn_19166 - can't get it to install
                    cgmoore64 Level 1
                    Anyone have any suggestions on how to resolve?
                    • 7. Re: Flash 9: Failed to Install tn_19166 - can't get it to install
                      dr00t
                      Having the same problem.
                      Using XP with Internet Explorer 7. My firefox works fine, but I need to get Flash Player working in my IE7.
                      • 8. Re: Flash 9: Failed to Install tn_19166 - can't get it to install
                        dr00t Level 1
                        Alright everyone, I have solved this issue. I hope it works for all of you as well.
                        You must have administrator privileges to successfully complete these instructions.
                        1. Follow the instructions to download the SubInACL tool from the Microsoft Download Center. Click Here
                        2. Install SubInACL.
                        3. Download the reset_minimal.zip file. Click Here
                        4. Extract the reset_minimal.cmd file to C:\Program Files\Windows Resource Kits\Tools\.
                        5. *Important: Be sure that both the subinacl.exe and reset_minimal.cmd files are in the same location here: C:\Program Files\Windows Resource Kits\Tools\.
                        6. Double-click reset_minimal.cmd.
                        7. This will open a command window and execute the SubInACL tool.
                        8. Do not use the machine while SubInACL is running.
                        9. When it is finished you will see "Press any key to continue".
                        10. Install the Flash Player from www.adobe.com/go/getflashplayer.
                        • 9. Re: Flash 9: Failed to Install tn_19166 - can't get it to install
                          Arrghmatey Level 1
                          I have this tool, and it did work once, then (probably after some MS update, or perhaps after installling Adobe Creative Suite) the player problem resurrected itself. I reused this tool which I'd kept in my downloaded files with no luck. Do you think I need to reinstall the SubInACL tool?
                          • 10. Re: Flash 9: Failed to Install tn_19166 - can't get it to install
                            dr00t Level 1
                            I would recommend doing so. Let us know how that goes.
                            • 11. Re: Flash 9: Failed to Install tn_19166 - can't get it to install
                              fdarweesh
                              This message to Adobe Stuff:
                              Does this problem happened from Adobe side or Microsoft side
                              Because for me as developer ,it is not how to solve this problem for me,it is beyound that
                              To how my application users will install the player again
                              Since this problem touch the main core of our business when flash player looses internet spread and popularity
                              Feras Darweesh
                              • 12. Re: Flash 9: Failed to Install tn_19166 - can't get it to install
                                fdarweesh Level 1
                                Ok i'd tryed this way and it doesnt work for me ,after that I'd downloaded the uninstall_flash_player.exe from adobe
                                and make the uninstalling ,after this I'd did your 10 steps and now it is working
                                • 13. Re: Flash 9: Failed to Install tn_19166 - can't get it to install
                                  jlici
                                  I tried all the steps that you suggested...I still get the message "failure to insatall Active X control....Is this the same message that you were receiving ?
                                  • 14. Re: Flash 9: Failed to Install tn_19166 - can't get it to install
                                    cgmoore64 Level 1
                                    It worked for me. I first uninstalled Flash and then went through the steps out-lined and it all works fine for me.
                                    Chris
                                    • 15. Re: Flash 9: Failed to Install tn_19166 - can't get it to install
                                      Darren McNally - Adobe Level 1
                                      If you’re having difficulties with the ActiveX installer on IE these steps will typically resolve the issue:
                                      Try this first: Instructions for uninstalling and reinstalling the Flash Player:
                                      1. First download the uninstaller to your desktop from here http://www.adobe.com/go/tn_14157
                                      2. Before running this uninstaller be sure to read the instruction and close all running programs.
                                      3. Open the following folder C:\WINDOWS\system32\Macromed\Flash
                                      4. Run the uninstaller
                                      5. What files are left in this folder? C:\WINDOWS\system32\Macromed\Flash
                                      6. If there are files left, delete the Flash folder.
                                      7. Install the Flash Player from here: ] http://www.adobe.com/go/getflashplayer
                                      8. Test the Flash Player here: http://www.adobe.com/products/flash/about/
                                      Also check your Internet Explorer ActiveX settings
                                      Browser security settings should be chosen by you or by your system administrator. For single users who do not have an administrator, the Medium: Default Level allows you to view Flash content. For any Custom Level, ensure that both the "Download Signed ActiveX controls" and "Run ActiveX controls and plug-ins" options are set to "Prompt".
                                      To change your security level:
                                      1. Open Internet Explorer.
                                      2. Choose Tools > Internet Options.
                                      3. Select the Security tab.
                                      4. Select Custom Level.
                                      5. Find the section "ActiveX controls and plug-ins".
                                      6. Set ' Download Signed ActiveX Controls' to Prompt.
                                      7. Set 'Run ActiveX Controls And Plug-ins' to Prompt.
                                      If you are having trouble, make sure that your Internet Explorer security level is not set to High or to a custom level that does not allow viewing of ActiveX controls.
                                      Finally, it may be that you have incorrect permissions in the system registry:
                                      To fix these Windows system registry permission conflicts you can use Microsoft’s SubInACL tool.
                                      Please download Microsoft’s tool to your desktop.
                                      http://www.supportflash.com/reset_min.zip
                                      1. Login as the User that has the incorrect permissions in the system registry
                                      2. unzip the “reset_minimal.cmd” and the “subinacl.exe” to the desktop
                                      *** Make sure both files are on the desktop
                                      3. Close out all applications
                                      4. Run the “reset.cmd” file
                                      5. It will open a DOS like terminal and start running through registry keys
                                      6. When it is finished it will say “press any key to continue”
                                      7. At this point you can download the latest Flash Player from here:
                                      • 16. Re: Flash 9: Failed to Install tn_19166 - can't get it to install
                                        BUZZ_KPO
                                        • 17. Re: Flash 9: Failed to Install tn_19166 - can't get it to install
                                          BUZZ_KPO Level 1
                                          Fantastic. I followed your instructions and it solved my problem.
                                          • 18. Re: Flash 9: Failed to Install tn_19166 - can't get it to install
                                            ZooeyC
                                            Darren at Adobe,
                                            Thanks for getting involved on this issue. My Flash has not worked in about two months.
                                            I have followed all of your suggestions but still no luck. After performing all the fix steps and when attempting to install from the adobe.com/go/getflashplayer page I get a tn_19166 error message again. Also, when I ran the reset_minimal.cmd, which runs subinacl.exe in the registry, and I look back at what it did in the registry, the only message displayed over and over is (something like) "did not recogize subinacl as an internal or external command." Does this mean it is not fixing the registry problem?
                                            Please let me know if you have any other suggestions to fix. Thanks.
                                            • 19. Flash 9: Failed to Install tn_19166 - can't get it to install
                                              googoogajoo
                                              I found a solution that may help with the Flash Player installation. I have Windows XP Home and Internet Explorer 7. I did EVERYTHING tech support and other users suggested, but had no luck on Internet Explorer. I followed the suggestion to download Firefox, and then I was able to download and use Flash Player, but it would only work with Firefox. It would not work with Explorer.
                                              Coincidentally, in trying to open another unrelated application, I was told that Windows could not open it and I chose the option to use the Internet to search for a way to open it. It prompted to download additional software, and one of the options was a free version of a registry compression tool called "Stuffit". After downloading and installing Stuffit, I once again followed Adobe tech support's original instructions for Flash Player.
                                              1. Make sure you are in Administrator Mode.
                                              2. Make sure your Active X settings are correct.
                                              3. Make sure your popup blocker is turned off.
                                              4. Use the Flash Player uninstaller, making sure all applications are closed, and all users are logged off.
                                              5. Then download Flash Player 9 using a standalone installer from the following:
                                              http://www.adobe.com/go/tn_14266 (Archived Adobe Flash Players available for testing purposes).
                                              6. After downloading the installer, make sure all other applications and windows are closed, then open the “9r115”
                                              folder and run the “flashplayer9r115_winax.exe” file.
                                              7. Afterwards, verify if the Flash Player installed successfully by going to the version test page:
                                              http://www.adobe.com/go/tn_15507
                                              This finally worked for me after NOTHING else did. I hope it helps you.
                                              • 22. Re: Flash 9: Failed to Install tn_19166 - can't get it to install
                                                Arrghmatey Level 1
                                                It seems like there are two problems. I can download and install the player plug in but not Active X controls. I believe the tool from MS is worthless but takes up alot of space, if I can translate it's goggly goo it says there are problems in the registry but doesn't fix them.
                                                I can live w/o flashy stuff on my pages however I'm wanting to install a program dependent on Active X controls. It gives the message 'failed to initiate flash player. Please re-install (the program)'.
                                                How are people having success with the stand-alone installers...you'd think when the Active X file is separate I'd have more installation luck but I get the same 19166 message?
                                                Psychiatrists are probably doubling their income from these 'tiny' software glitches...
                                                • 23. Re: Flash 9: Failed to Install tn_19166 - can't get it to install
                                                  Vervear
                                                  You will not read too far 'til you realize I am not too smart at this. I just want flash Have tried for months and months to install flash. Can you tell me what the line means that says "You must have administrator privileges to successfully complete these instructions"?
                                                  • 24. Re: Flash 9: Failed to Install tn_19166 - can't get it to install
                                                    dr00t Level 1
                                                    It means that when you log into a computer, unless you have "administrative" priviledges, you probably will not be able to use my instructions.
                                                    You should be able to try the instructions, and if you end up not having administrative priviledges, then it will let you know you do not have permission to perform my instructions.
                                                    If you don't, then please come back and let us know so we can help you further. Good luck.
                                                    • 25. Re: Flash 9: Failed to Install tn_19166 - can't get it to install
                                                      Y1411
                                                      Have tried all the steps that I have read of, but instead of seeing the FLV movie to verify the installation, I get a blank wintow with the small 'X' box in the upper left corner. What am I missing?
                                                      • 26. Re: Flash 9: Failed to Install tn_19166 - can't get it to install
                                                        rcvanderplaat
                                                        Hi, I have given up trying to get flash going on IE7, there is a exelent offline installer for firefox, why isnt there a offline installer for IE? it would make life much easier.
                                                        I am turning into a grumpy old man and getting cranky with the world with vista and IE causing me pain! Ah!!
                                                        Please make life easy again, make a offline installer avalable! or let me know the URL... I cant find one on google.
                                                        • 27. Re: Flash 9: Failed to Install tn_19166 - can't get it to install
                                                          wongnog
                                                          Hey guys, I am having the same problems installing Flash 9 on IE7 with WinXP Pro SP3. I have run the uninstaller (checked the log and made sure everything was removed", run subinacl and the reset_minimal.cmd file, checked my active-x and IE security settings, have an administrator account, disabled all popup blockers and anti-virus programs (basically all my background programs are exited), but I still can't install the Flash Player 9 Active-X for Internet Explorer. I also can't install it from the Flash page which downloads it directly to IE7. Here is a copy of my install.log file, I hope this helps someone.
                                                          • 28. Re: Flash 9: Failed to Install tn_19166 - can't get it to install
                                                            quote:
                                                            Originally posted by: ZooeyC
                                                            Darren at Adobe,
                                                            Hi ZooeyC,
                                                            If you receive the following message when running Microsoft’s SubInACL tool, "did not recognize SubInACL as an internal or external command", it may be that both the reset_min.cmd file and SubInACL are NOT located in the same directory (for example you’re desktop). Please try the following:
                                                            1. Please download Microsoft’s tool to your desktop.
                                                            If the ActiveX install still fails after these instructions please open a FREE Technical Support case from here:
                                                            http://www.adobe.com/support/contact/
                                                            Reply with the case number and I will help you resolve this issue.
                                                            • 29. Re: Flash 9: Failed to Install tn_19166 - can't get it to install
                                                              quote:
                                                              Hi wongnog,
                                                              Please open a FREE Technical Support case from here:
                                                              • 30. Re: Flash 9: Failed to Install tn_19166 - can't get it to install
        WebmasterBlog Level 1
        I hawe read here a solution of this problem, but i don't finf it now. Search for it.
        • 31. Re: Flash 9: Failed to Install tn_19166 - can't get it to install
        drakontes
        Thank you very much!
        I tried uninstalling/reinstalling the flash player first, but no joy.
        Changing my security settings didn't make any difference.
        Ran reset.cmd file and that worked. Thank you very much!
        Prior to running the reset.cmd file, CS3's Production Premium updater unsuccessfully attempted to install updates, several times. Each time I was prompted to reinstall my software. After running the reset.cmd file, the updater successfully installed all the updates and everything appears to be good to go.
        I wasn't looking forward to uninstalling/reinstalling my software and it turns out I didn't have to...so thanks again.
        • 32. Re: Flash 9: Failed to Install tn_19166 - can't get it to install
        quote:
        Originally posted by: drakontes
        Incorrect permissions in the system registry:
        Thanks drakontes,
        Glad to hear that you got this resolved. SubInACL is a Microsoft program that repairs permissions. For others out there experiencing issues with Windows IE ActiveX installers, this might help you.
