4 Replies Latest reply on Nov 10, 2018 12:05 PM by Txabi
    Something like "snap" two sequences
    Txabi
      Hello,
      I have two identical sequences. In the first one, I have fx in a lot of clips and in the other sequence I have only the Color Correction.
      Now I'd like to check all the clips and copy-paste some of those effects from Sequence A to Sequence B.
      Is there a way to "SNAP" those two sequences? So when I play Sequence B and I find one of those clips that I want to paste Fx, automaticaly see this clip in the A sequence's playhead.
      Txabi
        • 1. Re: Something like "snap" two sequences
          Peru Bob Adobe Community Professional & MVP
          Sequence A on V1, sequence B on V2.
          Turn off visibility of V2 to see V1.
          • 2. Re: Something like "snap" two sequences
            Txabi Level 1
            Thank you Peru for your answer but this is not what I'm looking for.  This method doesn't help me with the workflow.
            • 3. Re: Something like "snap" two sequences
              Meg The Dog Adobe Community Professional
              Have both Sequence A & B loaded in the program monitor so that you can tab between the two sequences in the timeline.
              Click on the tab for Sequence A and move the playhead to the beginning of the sequence.
              Load Sequence B from the project panel into the source monitor, and take the playhead of the source monitor to the start of the sequence.
              Return to the Program Monitor, and click on the wrench in the lower right corner of the monitor and from the drop down menu choose "Gang Source and Program".
              Now the two will move in tandem, and by tabbing between them in the in timeline you should be able to copy and paste your effect(s).
              MtD
              4 people found this helpful
              • 4. Re: Something like "snap" two sequences
                Txabi Level 1
                Thank you Meg!
                "Gang" is the key. I didn't remenber the word but I remenber using it on Final Cut Pro.
                Anyway it only solves a half of what it'd like to do.
                Now both senquences are "ganged" on Source and Program, but not the playheads of both timelines.
                Is there a waye to Match frame from source to Timeline? I didn't find it in Shortcuts.
                Txabi
