1 Reply Latest reply: Jan 22, 2008 8:49 AM by Newsgroup_User RSS
    Align Objects
    David C Johnson Community Member
      The help file is apparently worthless to me. I want to align two objects, but I want one of them to stay put and the other to move. Flash doesn't work like Illustrator. (select all objects, select master object again, click align center - all objects except master move.) Flash doesn't work like the 4.6 trillion other drawing tools I've used. (select each object, and the last object selected is the master - all objects except master move).
      I have a line and an oval. No matter which combination of select-first, select-last, whatever I do, Flash ALWAYS moves the line. However, if I have two rectangles, Flash ALWAYS moves both.
      What am I missing here?
        • 1. Re: Align Objects
          Newsgroup_User Community Member
          David,
          If -- just for example -- you're aligning right in the Align panel and
          the "To stage" is button is deselected, then the right-most object will stay
          put, while the left-most object will move right to meet it. If you're
          aligning top, the top-most object will stay put, while the lower upject will
          move up to meet it. And so on.
          That sounds like a cool feature.
          > I've used.
          Heh. My Illustrator buddies call me crazy, but I really do prefer to
          draw in Flash. To each his own, of course -- but in any case, experiment
          with the "To stage" button to understand the difference that occurs when
          it's selected versus deselected. And again, keep in mind that the left-,
          right-, etc.-most object is the "master" object when aligning in that
          direction.
          David Stiller
          Co-author, Foundation Flash CS3 for Designers
          http://tinyurl.com/2k29mj
          "Luck is the residue of good design."
