I recently edited a photo from my Lightroom catalog in Photoshop. I then saved it as a TIFF. It automatically imported the photo exactly where it should, but on the right side of the image, there are now semi-transparent red and cyan rectangles. I don't see these in Photoshop, but they're visible in Lightroom. Does anyone know what might be causing this?
jasonl79951632 wrote
Closing and reopening Lightroom didn't work. Saving the file in another place and re-importing didn't work. Using 'Legacy Compositing' and reimporting into Lightroom fixed the issue.
It was a layered file. I made multiple adjustment layers in Photoshop and saved it as a layered file in case I wanted to tweak the adjustments again later.
Was this likely a bug that Legacy Compositing worked around?
Yes. Because Lightroom does not support layers, it reads the composite that i
...Copy link to clipboard
Probably a bug, there have been similar reports.
Please report this as a bug at: https://feedback.photoshop.com/photoshop_family/categories/photoshop_family_photoshop_lightroom
Try this. In Photoshop Preferences - Performance, check the option to use 'Legacy Compositing'.
One other option to try:
Close Lightroom and restart it - sometimes, a file does not completely load right away and the preview you get is only partial!
Did PS create any layers, and did you flatten/merge the layers, or did you go for the larger, more complex layered file? Should not be the issue, but perhaps point to a symptom.
Might relate to this : https://petapixel.com/2018/10/19/beware-theres-a-blend-mode-bug-in-photoshop-cc-2019/
Yes. Because Lightroom does not support layers, it reads the composite that is saved as well. But there seems to be a bug in the new way that Photoshop creates this composite.
