Hey everyone!
I wrote a script that is a part of bigger script and my export action
It checks if job is for one of my two clients (based on text frames content), then if layer named "farmakod" exists, then if "farmakod" is empty.
var docRef = app.activeDocument;
function doesLayerExist(layers, name) {
for (i = 0; i < layers.length; i++) {
if (layers.name == name) return true;
return false;
function checkPharmaCode() {
if (doesLayerExist(docRef.layers, "farmakod")) {
var targetLayer = app.activeDocument.layers.getByName("farmakod");
if (targetLayer.pageItems.length == 0) {
alert("Missing pharmacode on 'farmakod' layer!");
} else {};
} else {
alert("Missing layer 'farmakod'!")
function checkPharmacy() {
var frames = docRef.textFrames;
for (var x = frames.length - 1; x >= 0; x--) {
if ((frames
.contents.indexOf("CLIENT1") > -1) || (frames .contents.indexOf("CLIENT2") > -1)) { checkPharmaCode()
} else {}
checkPharmacy();
Right now i only have an alert information, but the script (and action) are stil going after closing an alert.
And since the script is exporting my file as pdf, i dont want to wait until the end of the proccess, just to fix everything, and start script once again.
I was doing some searching and as far as i know there is no simple way to stop a script to let user make some changes (in my ex. creating a layer and inserting a content).
Palette window is not an answer - i can do my changes, but script is still working
Dialog window - stops a script, but doesn't allow to click anything besides window itself.
Is there any workaround for this issue?
Like setting $.sleep for 10min, and after clicking OK on palette window the $.sleep would be interrupted or changed to 0?
Or something like clearTimeout ?
Also some code review would be appreciated
Sorry for my english.
Then just condition the script execution to layer's presence.
var main = function() {
var doc, layers, farmakodLayer;
if ( !app.documents.length ) {
alert("This scripts needs an open document !");
return;
doc = app.activeDocument;
layers = getLayers(doc);
if ( typeof layers["farmakod"]=="undefined" ) {
alert("You need farmakod layer to get this script running");
return;
alert("Now you can execute sub routines");
function getLayers(kDoc){
var kLayers = kDoc.layers, n = kLayers.length, o = {}, nKLayer;
while ( n-- ) {
nKLayer = kLayers
; o[nKLayer.name] = nKLayer;
return o;
main();
HTH
Thank you very much for your answer but it's not really the solution for my problem
As I said the script i posted is a part of a bigger script that is a part of an action that i use to export files as Normalized PDF via Esko plugin.
The action looks like this:
After canceling the script an action will go on, and i would want to fix the problem before exporting a file.
Like:
if there is no "farmakod" layer or it's empty, the script is paused and the user can create the layer and put necessary objects, and then let the action continue
unfortunately i have no idea how to script the export part (which would be a simple solution) since it's a third party plugin (in fact, I found a tutorial on scripting export process among ESKO files, but I did not understand much of it, and I do not know if I can share it publicly with someone who would help me with this issue)
maybe the solution would be starting an action (only Export as... part) from script and condition execution as you suggested
Like:
script {
if everything is ok
continue process normally:
do script stuff
execute action "Export as.." - via Esko plugin
do other script stuff
else
abort process
is this possible?
also i have no idea how your script works, especially getLayer function
Is there a way you can invert your flow to make the script play your actions instead?
I could be wrong but I think there is no "pause" concept in ExtendScript. Of course, one can argue there is a $.sleep command but it just freezes the script engine execution and the app in a modal state.
So you probably need to check eveything before you run the whole routine just as you indicated.
My getLayer function intends to avoid execution errors when using doc.layers.getByName ("someLayerName"). The latter throws error if no such layer exists. So that's a way I found to possibly deal with non existing layers by creating a javascript object whose properties are layers's names. Eventually, I can "reach" a non existing layer without errors.
Loic.Aigon thank you for your answers and improved script
unfortunately not what i wanted, but exactly what I expected
Silly-V it seems to me that it is very likely and to be done
just like i wrote earlier
script {
if everything is ok
do script stuff
else
abort process/do nothing
I have seen your post about dynamic action scripting, is this a right direction to do what we are talking about ?
Ok i found a way to play action via script (much simpler than i thought),
I'm currently rewriting my script to work just as you suggested,but i have encountered another problem (error 1200), which I will no longer discuss in this post, not to make a mess
Salut, autre solution...
// JavaScript Document
/*getLayerbyName.js*/
if (app.documents.length){main();}
function main() {
var testLayer = getLayers(doc,"farmakod");
if (testLayer == undefined) {
return;
}//run action
alert("Passed ")
}function getLayers(relativObjet,layerName)
try {
var klayer = relativObjet.layers.getByName(layerName);
} catch (e) {
//alert( "The specified layer doesn’t exist" );
return undefined; // undefined if not exist
return klayer;
de elleere
Oui mais l'intérêt de l'objet c'est que tu peux le charger au début du script et y revenir au besoin sans rappeler la fonction
I think is it possible to do in dynamic action
Hi, bro ( or sis (: )
5 frigging years later, but it's one of the first results on Google so it might help some people.
You can open a "file select"
If those layers are missing, wouldn't you just want to exit the larger script so it can be fixed, then execute the script again? Could you integrate what you have at the beginning of the script to exit out?
Edit: For some reason, replies hadn't shown up when I replied to this.
