12 Replies Latest reply on May 12, 2008 11:48 AM by CHAOS'|nc.
    Sound problems
      Ok i'm not sure how to put the .fla file on for you to see the problem but ill explain as best as possible.
      Basically i press a button, a ball builds up, then it fires, but when it fires a nice catchy little "HADOKEN" is shouted. When i let go the sound stops. But.... i have to hold down spacebar for the ball to build up and fire. So when it gets to firing stage, as i fire the ball and hadoken is shouted, it is shouted many times because i have to hold down button, how do i get it to play the sound only once even with key held down, either explain or attach code.
      Thanks very much in advance.
      Here is my script: (Thanks Flashtastic for all your help)
