Hi Community,
Recently i trying to install SP2 on AEM6.4 GA instance, but it does not install anything.
This instance also has installed AEM6.4 Forms Add on package for linux.
This issue only happen on specific instance, because i cant simulate this issue on a fresh instance, or other instance in other environment.
I install SP2 via package manager, by right after package is installed, it will prompt alert for server restart is require. But it does not prompt any.
15.11.2018 11:09:23.834 *INFO* [qtp409938068-60] com.day.crx.packaging.impl.SlingInstallerSupportImpl Sling installer node /system/sling/installer/jcr/pauseInstallation/e599260e-aea7-4332-b62d-e3c3850a7f25/com.day.crx.packaging.impl.SlingInstallerSupportImpl/58160905-e247-41d3-9eb2-2b56c2f2b884 created.
15.11.2018 11:09:25.802 *INFO* [qtp409938068-60] org.apache.jackrabbit.vault.packaging.impl.ActivityLog adobe/cq640/servicepack/.snapshot:aem-service-pkg:6.4.2: CREATE
15.11.2018 11:09:26.069 *INFO* [qtp409938068-60] com.day.crx.packaging.impl.J2EEPackageManager Found installable at /libs/system/config/.content.xml
15.11.2018 11:09:26.161 *INFO* [qtp409938068-60] org.apache.jackrabbit.vault.packaging.impl.ActivityLog adobe/cq640/servicepack/.snapshot:aem-service-pkg:6.4.2: SNAPSHOT
15.11.2018 11:09:31.645 *INFO* [qtp409938068-60] org.apache.jackrabbit.vault.packaging.impl.ActivityLog adobe/cq640/servicepack:aem-service-pkg:6.4.2: INSTALL
15.11.2018 11:09:31.683 *INFO* [qtp409938068-60] com.day.crx.packaging.impl.SlingInstallerSupportImpl Sling installer node /system/sling/installer/jcr/pauseInstallation/e599260e-aea7-4332-b62d-e3c3850a7f25/com.day.crx.packaging.impl.SlingInstallerSupportImpl/58160905-e247-41d3-9eb2-2b56c2f2b884 removed.
15.11.2018 11:09:31.683 *INFO* [qtp409938068-60] com.day.crx.packaging.impl.J2EEPackageManager Scanner detected potential jcr installable. delaying installation for 2 seconds.
I also try to install package via Web Console, and it does restart the instance but it stuck at when restarting bundle.
15.11.2018 11:11:24.696 *INFO* [FelixStartLevel] com.adobe.granite.apicontroller BundleEvent STOPPED
15.11.2018 11:11:24.696 *INFO* [FelixDispatchQueue] org.apache.felix.framework FrameworkEvent STARTLEVEL CHANGED to 1
15.11.2018 11:11:24.889 *ERROR* [Thread-1561] com.adobe.granite.installer.Updater Unable to finish updating bundle
java.lang.NullPointerException: null
at com.adobe.granite.maven.packaging.impl.support.Data.writeData(Data.java:158) [updater.aem-service-pkg:1.0.0]
at com.adobe.granite.maven.packaging.impl.support.Data.setStateAndWriteData(Data.java:149) [updater.aem-service-pkg:1.0.0]
at com.adobe.granite.maven.packaging.impl.support.BundleUpdater.run(BundleUpdater.java:230) [updater.aem-service-pkg:1.0.0]
at java.lang.Thread.run(Unknown Source)
15.11.2018 11:11:30.000 *INFO* [CommitStats] CommitStats run: commit stats logger [#2] quits.
Do you have any idea what is blocking from package installing successful?
Fisher
Views
Total Likes
