• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
2
Bug - Image and Layer options are greyed out if and only if Photoshop CC 2019 is launched from Lightroom CC Classic
Community Beginner ,
Nov 14, 2018 Nov 14, 2018
To reproduce:
1. open Lightroom CC Classic,
2. select any images, and right click then select 'Edit in Adobe Photoshop CC 2019'
3. once the image is opened in Photoshop CC 2019, the options under Image and Layers are all greyed out.
The workaround is:
2. open Photoshop CC 2019,
3. Select any images, and right click then select 'Edit in Adobe Photoshop CC 2019'
4. once the image is opened in Photoshop, the options under Image and Layers are now available.
System Information:
Lightroom Classic version: 8.0 [ 1193777 ]
License: Creative Cloud
Language setting: en
Operating system: Windows 10 - Business Edition
Version: 10.0.17134
Application architecture: x64
System architecture: x64
Logical processor count: 8
Processor speed: 3.3 GHz
Built-in memory: 16339.2 MB
Real memory available to Lightroom: 16339.2 MB
Real memory used by Lightroom: 2846.0 MB (17.4%)
Virtual memory used by Lightroom: 3614.6 MB
GDI objects count: 703
USER objects count: 2317
Process handles count: 2006
Memory cache size: 0.0MB
Internal Camera Raw revision: 61
Maximum thread count used by Camera Raw: 5
Camera Raw SIMD optimization: SSE2,AVX
Camera Raw virtual memory: 665MB / 8169MB (8%)
Camera Raw real memory: 685MB / 16339MB (4%)
System DPI setting: 96 DPI
Desktop composition enabled: Yes
Displays: 1) 1920x1200, 2) 1280x1024
Input types: Multitouch: No, Integrated touch: No, Integrated pen: Yes, External touch: No, External pen: Yes, Keyboard: No
Graphics Processor Info:
DirectX: NVIDIA Quadro K1200 (23.21.13.9065)
Application folder: C:\Program Files\Adobe\Adobe Lightroom Classic CC
Library Path: E:\Photos\Lightroom\Lightroom Catalog.lrcat
Settings Folder: C:\Users\Admin\AppData\Roaming\Adobe\Lightroom
Installed Plugins:
1) AdobeStock
2) Canon Tether Plugin
3) Facebook
4) Flickr
5) Nikon Tether Plugin
Config.lua flags: None
Adapter #1: Vendor : 10de
Device : 13bc
Subsystem : 114010de
Revision : a2
Video Memory : 4053
Adapter #2: Vendor : 1414
Device : 8c
Subsystem : 0
Revision : 0
Video Memory : 0
AudioDeviceIOBlockSize: 1024
AudioDeviceName: Speakers (High Definition Audio Device)
AudioDeviceNumberOfChannels: 2
AudioDeviceSampleRate: 48000
Build: 12.1x4
Direct2DEnabled: false
GL_ACCUM_ALPHA_BITS: 16
GL_ACCUM_BLUE_BITS: 16
GL_ACCUM_GREEN_BITS: 16
GL_ACCUM_RED_BITS: 16
GL_ALPHA_BITS: 0
GL_BLUE_BITS: 8
GL_DEPTH_BITS: 24
GL_GREEN_BITS: 8
GL_MAX_3D_TEXTURE_SIZE: 4096
GL_MAX_TEXTURE_SIZE: 16384
GL_MAX_TEXTURE_UNITS: 4
GL_MAX_VIEWPORT_DIMS: 16384,16384
GL_RED_BITS: 8
GL_RENDERER: Quadro K1200/PCIe/SSE2
GL_SHADING_LANGUAGE_VERSION: 4.60 NVIDIA
GL_STENCIL_BITS: 8
GL_VENDOR: NVIDIA Corporation
GL_VERSION: 4.6.0 NVIDIA 390.65
GPUDeviceEnabled: false
OGLEnabled: true
GL_EXTENSIONS: GL_AMD_multi_draw_indirect GL_AMD_seamless_cubemap_per_texture GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_bindless_texture GL_ARB_blend_func_extended GL_ARB_buffer_storage GL_ARB_cl_event GL_ARB_clear_buffer_object GL_ARB_clear_texture GL_ARB_clip_control GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_compute_shader GL_ARB_compute_variable_group_size GL_ARB_conditional_render_inverted GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_cull_distance GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_derivative_control GL_ARB_direct_state_access GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_indirect GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_ES3_1_compatibility GL_ARB_ES3_2_compatibility GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_get_texture_sub_image GL_ARB_gl_spirv GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_gpu_shader_int64 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_indirect_parameters GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multi_draw_indirect GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_parallel_shader_compile GL_ARB_pipeline_statistics_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_polygon_offset_clamp GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_query_buffer_object GL_ARB_robust_buffer_access_behavior GL_ARB_robustness GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_seamless_cubemap_per_texture GL_ARB_separate_shader_objects GL_ARB_shader_atomic_counter_ops GL_ARB_shader_atomic_counters GL_ARB_shader_ballot GL_ARB_shader_bit_encoding GL_ARB_shader_clock GL_ARB_shader_draw_parameters GL_ARB_shader_group_vote GL_ARB_shader_image_load_store GL_ARB_shader_image_size GL_ARB_shader_objects GL_ARB_shader_precision GL_ARB_shader_storage_buffer_object GL_ARB_shader_subroutine GL_ARB_shader_texture_image_samples GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_sparse_buffer GL_ARB_sparse_texture GL_ARB_spirv_extensions GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_tessellation_shader GL_ARB_texture_barrier GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_filter_anisotropic GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_transform_feedback_overflow_query GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_64bit GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_polygon_offset_clamp GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shader_image_load_formatted GL_EXT_shader_image_load_store GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback2 GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_vertex_attrib_64bit GL_EXT_window_rectangles GL_EXT_import_sync_object GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KHR_context_flush_control GL_KHR_debug GL_EXT_memory_object GL_EXT_memory_object_win32 GL_EXT_win32_keyed_mutex GL_KHR_parallel_shader_compile GL_KHR_no_error GL_KHR_robust_buffer_access_behavior GL_KHR_robustness GL_EXT_semaphore GL_EXT_semaphore_win32 GL_KTX_buffer_region GL_NV_alpha_to_coverage_dither_control GL_NV_bindless_multi_draw_indirect GL_NV_bindless_multi_draw_indirect_count GL_NV_bindless_texture GL_NV_blend_equation_advanced GL_NV_blend_equation_advanced_coherent GL_NV_blend_minmax_factor GL_NV_blend_square GL_NV_command_list GL_NV_compute_program5 GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_deep_texture3D GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_draw_texture GL_NV_draw_vulkan_image GL_NV_ES1_1_compatibility GL_NV_ES3_1_compatibility GL_NV_explicit_multisample GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_gpu_program4 GL_NV_internalformat_sample_query GL_NV_gpu_program4_1 GL_NV_gpu_program5 GL_NV_gpu_program5_mem_extended GL_NV_gpu_program_fp64 GL_NV_gpu_shader5 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_path_rendering GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_query_resource GL_NV_query_resource_tag GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_shader_atomic_counters GL_NV_shader_atomic_float GL_NV_shader_atomic_int64 GL_NV_shader_buffer_load GL_NV_shader_storage_buffer_object GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_rectangle_compressed GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_transform_feedback2 GL_NV_uniform_buffer_unified_memory GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_attrib_integer_64bit GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_NVX_multigpu_info GL_NVX_nvenc_interop GL_NV_shader_thread_group GL_NV_shader_thread_shuffle GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control
Photoshop CC 2019 System Info:
Adobe Photoshop Version: 20.0.1 20181029.r.41 2018/010/29: 1197484  x64
Number of Launches: 5
Operating System: Windows 10 64-bit
Version: 10 or greater 10.0.17134.1
System architecture: Intel CPU Family:6, Model:10, Stepping:7 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
Physical processor count: 4
Processor speed: 3392 MHz
Built-in memory: 16339 MB
Free memory: 10463 MB
Memory available to Photoshop: 14948 MB
Memory used by Photoshop: 70 %
Alias Layers: Disabled.
Modifier Palette: Enabled.
Highbeam: Enabled.
Image tile size: 1024K
Image cache levels: 4
Font Preview: Medium
TextComposer: Latin
Display: 1
Display Bounds: top=0, left=0, bottom=1200, right=1920
Display: 2
Display Bounds: top=0, left=-1280, bottom=1024, right=0
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=1
NumNativeGPUs=0
glgpu[0].GLVersion="4.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=4096
glgpu[0].GLName="NVIDIA Quadro K1200"
glgpu[0].GLVendor="NVIDIA Corporation"
glgpu[0].GLVendorID=4318
glgpu[0].GLDriverVersion="23.21.13.9065"
glgpu[0].GLRectTextureSize=16384
glgpu[0].GLRenderer="Quadro K1200/PCIe/SSE2"
glgpu[0].GLRendererID=5052
glgpu[0].HasGLNPOTSupport=1
glgpu[0].GLDriver="C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_7cfe0cd2c62cb12c\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_7cfe0cd2c62cb12c\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_7cfe0cd2c62cb12c\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_7cfe0cd2c62cb12c\nvldumdx.dll"
glgpu[0].GLDriverDate="20180103000000.000000-000"
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.60 NVIDIA"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[65536]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[0].CLPlatformVersion="1.2"
clgpu[0].CLDeviceVersion="1.2 CUDA"
clgpu[0].IsIntegratedCLGPU=0
clgpu[0].CLMemoryMB=4096
clgpu[0].CLName="Quadro K1200"
clgpu[0].CLVendor="NVIDIA Corporation"
clgpu[0].CLVendorID=4318
clgpu[0].CLDriverVersion="390.65"
clgpu[0].CLBandwidth=6.33565e+10
clgpu[0].CLCompute=288.772
License Type: Subscription
Serial number: 96040918292375277720
GUIDBucket:Composite Core (enable_composite_core): onComposite Core UI (comp_core_ui): offDocument Graph (enable_doc_graph): off
Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2019\
Temporary file path: C:\Users\Admin\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
  Startup, 237.5G, 86.4G free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2019\Required\Plug-Ins\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2019\Plug-Ins\
Installed components:
   A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
   ACE.dll   ACE 2018/09/06-18:53:59   79.601691   79.601691
   AdbePM.dll   PatchMatch 2018/09/10:19:04:15   1.601805   1.601805
   AdobeLinguistic.dll   Adobe Linguisitc Library   13.0.0.0
   AdobeOwl.dll   Adobe Owl   5.3.0
   AdobePDFL.dll   PDFL 2018/08/23-00:56:13   79.301181   79.301181
   AdobePIP.dll   Adobe Product Improvement Program   8.0.0.41.47939
   AdobeSVGAGM.dll   AdobeSVGAGM   79.600623   79.600623
   AdobeXMP.dll   Adobe XMP Core 2018/08/13-16:40:22   79.163499   79.163499
   AdobeXMPFiles.dll   Adobe XMP Files 2018/08/13-16:40:22   79.163499   79.163499
   AdobeXMPScript.dll   Adobe XMP Script 2018/08/13-16:40:22   79.163499   79.163499
   adobe_caps.dll   Adobe CAPS   10,0,0,6
   AGM.dll   AGM 2018/08/14-01:11:25   79.600623   79.600623
   ahclient.dll    AdobeHelp Dynamic Link Library   4.0.0.0
   AIDE.dll   AIDE 2018/08/10-16:31:38   79.600470   79.600470
   ARE.dll   ARE 2018/08/14-01:11:25   79.600623   79.600623
   AXE8SharedExpat.dll   AXE8SharedExpat 2018/06/25-18:00:38   79.598424   79.598424
   AXEDOMCore.dll   AXEDOMCore 2018/06/25-18:00:38   79.598424   79.598424
   Bib.dll   BIB 2018/08/14-01:11:25   79.600623   79.600623
   BIBUtils.dll   BIBUtils 2018/08/14-01:11:25   79.600623   79.600623
   boost_date_time.dll   photoshopdva   12.1.0
   boost_filesystem.dll   photoshopdva   12.1.0
   boost_system.dll   photoshopdva   12.1.0
   boost_threads.dll   photoshopdva   12.1.0
   cg.dll   NVIDIA Cg Runtime   3.0.00007
   cgGL.dll   NVIDIA Cg Runtime   3.0.00007
   CITThreading.dll   Adobe CITThreading   2.1.0.1   2.1.0.1
   CoolType.dll   CoolType 2018/08/14-01:11:25   79.600623   79.600623
   CRClient.dll   Adobe Crash Reporter Client DLL   2.0.3.0
   dnssd.dll   Bonjour   3,0,0,2
   dvaaccelerate.dll   photoshopdva   12.1.0
   dvaappsupport.dll   photoshopdva   12.1.0
   dvaaudiodevice.dll   photoshopdva   12.1.0
   dvacore.dll   photoshopdva   12.1.0
   dvacrashhandler.dll   Adobe Audition CC 2017   10.0.0
   dvamarshal.dll   photoshopdva   12.1.0
   dvamediatypes.dll   photoshopdva   12.1.0
   dvametadata.dll   photoshopdva   12.1.0
   dvametadataapi.dll   photoshopdva   12.1.0
   dvametadataui.dll   photoshopdva   12.1.0
   dvaplayer.dll   photoshopdva   12.1.0
   dvascripting.dll   photoshopdva   12.1.0
   dvatransport.dll   photoshopdva   12.1.0
   dvaui.dll   photoshopdva   12.1.0
   dvaunittesting.dll   photoshopdva   12.1.0
   dynamiclink.dll   photoshopdva   12.1.0
   ExtendScript.dll   ExtendScript 2017/08/31-12:13:14   81.1157194   81.1157194
   icucnv58.dll   International Components for Unicode   58, 2, 0, 0
   icudt58.dll   International Components for Unicode   58, 2, 0, 0
   icuuc58.dll   International Components for Unicode   58, 2, 0, 0
   igestep30.dll   IGES Reader   9.3.0.113
   JP2KLib.dll   JP2KLib 2018/06/25-18:00:38   79.271024   79.271024
   libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
   libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
   libmmd.dll   Intel(R) C/C++/Fortran Compiler   18.0.0
   LogSession.dll   LogSession   8.0.0.41.47939
   mediacoreif.dll   photoshopdva   12.1.0
   MPS.dll   MPS 2018/08/06-15:20:35   79.600183   79.600183
   pdfsettings.dll   Adobe PDFSettings   1.04
   Photoshop.dll   Adobe Photoshop CC 2019   20.0
   Plugin.dll   Adobe Photoshop CC 2019   20.0
   PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   9.2.1
   PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   9.2.1.39
   PSCloud.dll                                                   1.0.0.1
   PSViews.dll   Adobe Photoshop CC 2019   20.0
   SCCore.dll   ScCore 2017/08/31-12:13:14   81.1157194   81.1157194
   SVGRE.dll   SVGRE   79.600623   79.600623
   svml_dispmd.dll   Intel(R) C/C++/Fortran Compiler   18.0.0
   tbb.dll   Intel(R) Threading Building Blocks for Windows   2018, 0, 2017, 1205
   tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   2018, 0, 2017, 1205
   TfFontMgr.dll   FontMgr   9.3.0.113
   TfKernel.dll   Kernel   9.3.0.113
   TFKGEOM.dll   Kernel Geom   9.3.0.113
   TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
   VulcanControl.dll   Vulcan Application Control Library   5.3.0.16
   VulcanMessage5.dll   Vulcan Message Library   5.3.0.16
   WinRTSupport.dll   Adobe Photoshop Windows RT Support   20.0.0.0
   WRServices.dll   WRServices Tue August 14 2018 12:26:24   Build 0.23627   0.23627
   wu3d.dll   U3D Writer   9.3.0.113
Required plug-ins:
   3D Studio 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “U3D.8bi”
   Accented Edges 20.0 - from the file “Filter Gallery.8bf”
   Adaptive Wide Angle 20.0 - from the file “Adaptive Wide Angle.8bf”
   Angled Strokes 20.0 - from the file “Filter Gallery.8bf”
   Average 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “Average.8bf”
   Bas Relief 20.0 - from the file “Filter Gallery.8bf”
   BMP 20.0 - from the file “Standard MultiPlugin.8bf”
   Camera Raw 11.0 - from the file “Camera Raw.8bi”
   Camera Raw Filter 11.0 - from the file “Camera Raw.8bi”
   Chalk && Charcoal 20.0 - from the file “Filter Gallery.8bf”
   Chrome 20.0 - from the file “Filter Gallery.8bf”
   Cineon 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “Cineon.8bi”
   Clouds 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “Clouds.8bf”
   Collada 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “U3D.8bi”
   Color Halftone 20.0 - from the file “Standard MultiPlugin.8bf”
   Colored Pencil 20.0 - from the file “Filter Gallery.8bf”
   Conté Crayon 20.0 - from the file “Filter Gallery.8bf”
   Craquelure 20.0 - from the file “Filter Gallery.8bf”
   Crop and Straighten Photos 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “CropPhotosAuto.8li”
   Crop and Straighten Photos Filter 20.0 - from the file “Standard MultiPlugin.8bf”
   Crosshatch 20.0 - from the file “Filter Gallery.8bf”
   Crystallize 20.0 - from the file “Standard MultiPlugin.8bf”
   Cutout 20.0 - from the file “Filter Gallery.8bf”
   Dark Strokes 20.0 - from the file “Filter Gallery.8bf”
   De-Interlace 20.0 - from the file “Standard MultiPlugin.8bf”
   Dicom 20.0 - from the file “Dicom.8bi”
   Difference Clouds 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “Clouds.8bf”
   Diffuse Glow 20.0 - from the file “Filter Gallery.8bf”
   Displace 20.0 - from the file “Standard MultiPlugin.8bf”
   Dry Brush 20.0 - from the file “Filter Gallery.8bf”
   Eazel Acquire 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “EazelAcquire.8ba”
   Entropy 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “statistics.8ba”
   Export Color Lookup Tables 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “Export3DLUT.8be”
   Extrude 20.0 - from the file “Standard MultiPlugin.8bf”
   FastCore Routines 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “FastCore.8bx”
   Fibers 20.0 - from the file “Standard MultiPlugin.8bf”
   Film Grain 20.0 - from the file “Filter Gallery.8bf”
   Filter Gallery 20.0 - from the file “Filter Gallery.8bf”
   Flash 3D 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “U3D.8bi”
   Fresco 20.0 - from the file “Filter Gallery.8bf”
   Glass 20.0 - from the file “Filter Gallery.8bf”
   Glowing Edges 20.0 - from the file “Filter Gallery.8bf”
   Google Earth 4 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “U3D.8bi”
   Graphic Pen 20.0 - from the file “Filter Gallery.8bf”
   Halftone Pattern 20.0 - from the file “Filter Gallery.8bf”
   Halide Bottlenecks 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “HalideBottlenecks.8bx”
   HDRMergeUI 20.0 - from the file “HDRMergeUI.8bf”
   HSB/HSL 20.0 - from the file “Standard MultiPlugin.8bf”
   IFF Format 20.0 - from the file “Standard MultiPlugin.8bf”
   IGES 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “U3D.8bi”
   Ink Outlines 20.0 - from the file “Filter Gallery.8bf”
   JPEG 2000 20.0 - from the file “JPEG2000.8bi”
   Kurtosis 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “statistics.8ba”
   Lens Blur 20.0 - from the file “Lens Blur.8bf”
   Lens Correction 20.0 - from the file “Lens Correction.8bf”
   Lens Flare 20.0 - from the file “Standard MultiPlugin.8bf”
   Liquify 20.0 - from the file “Liquify.8bf”
   Matlab Operation 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “ChannelPort.8bf”
   Maximum 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “statistics.8ba”
   Mean 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “statistics.8ba”
   Measurement Core 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “MeasurementCore.8me”
   Median 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “statistics.8ba”
   Mezzotint 20.0 - from the file “Standard MultiPlugin.8bf”
   Minimum 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “statistics.8ba”
   MMXCore Routines 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “MMXCore.8bx”
   Mosaic Tiles 20.0 - from the file “Filter Gallery.8bf”
   Multiprocessor Support 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “MultiProcessor Support.8bx”
   Neon Glow 20.0 - from the file “Filter Gallery.8bf”
   Note Paper 20.0 - from the file “Filter Gallery.8bf”
   NTSC Colors 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “NTSC Colors.8bf”
   Ocean Ripple 20.0 - from the file “Filter Gallery.8bf”
   OpenEXR 20.0 - from the file “Standard MultiPlugin.8bf”
   Paint Daubs 20.0 - from the file “Filter Gallery.8bf”
   Palette Knife 20.0 - from the file “Filter Gallery.8bf”
   Patchwork 20.0 - from the file “Filter Gallery.8bf”
   Paths to Illustrator 20.0 - from the file “Standard MultiPlugin.8bf”
   PCX 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “PCX.8bi”
   Photocopy 20.0 - from the file “Filter Gallery.8bf”
   Picture Package Filter 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “ChannelPort.8bf”
   Pinch 20.0 - from the file “Standard MultiPlugin.8bf”
   Pixar 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “Pixar.8bi”
   Plaster 20.0 - from the file “Filter Gallery.8bf”
   Plastic Wrap 20.0 - from the file “Filter Gallery.8bf”
   PLY 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “U3D.8bi”
   Pointillize 20.0 - from the file “Standard MultiPlugin.8bf”
   Polar Coordinates 20.0 - from the file “Standard MultiPlugin.8bf”
   Portable Bit Map 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “PBM.8bi”
   Poster Edges 20.0 - from the file “Filter Gallery.8bf”
   PRC 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “U3D.8bi”
   Radial Blur 20.0 - from the file “Standard MultiPlugin.8bf”
   Radiance 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “Radiance.8bi”
   Range 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “statistics.8ba”
   Render Color Lookup Grid 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “Export3DLUT.8be”
   Reticulation 20.0 - from the file “Filter Gallery.8bf”
   Ripple 20.0 - from the file “Standard MultiPlugin.8bf”
   Rough Pastels 20.0 - from the file “Filter Gallery.8bf”
   Save for Web 20.0 - from the file “Save for Web.8be”
   ScriptingSupport 20.0 - from the file “ScriptingSupport.8li”
   Shake Reduction 20.0 - from the file “Shake Reduction.8bf”
   Shear 20.0 - from the file “Standard MultiPlugin.8bf”
   Skewness 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “statistics.8ba”
   Smart Blur 20.0 - from the file “Standard MultiPlugin.8bf”
   Smudge Stick 20.0 - from the file “Filter Gallery.8bf”
   Solarize 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “Solarize.8bf”
   Spaces 20.0 - from the file “Spaces.8li”
   Spatter 20.0 - from the file “Filter Gallery.8bf”
   Spherize 20.0 - from the file “Standard MultiPlugin.8bf”
   Sponge 20.0 - from the file “Filter Gallery.8bf”
   Sprayed Strokes 20.0 - from the file “Filter Gallery.8bf”
   Stained Glass 20.0 - from the file “Filter Gallery.8bf”
   Stamp 20.0 - from the file “Filter Gallery.8bf”
   Standard Deviation 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “statistics.8ba”
   STL 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “U3D.8bi”
   Sumi-e 20.0 - from the file “Filter Gallery.8bf”
   Summation 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “statistics.8ba”
   Targa 20.0 - from the file “Standard MultiPlugin.8bf”
   Texturizer 20.0 - from the file “Filter Gallery.8bf”
   Tiles 20.0 - from the file “Standard MultiPlugin.8bf”
   Torn Edges 20.0 - from the file “Filter Gallery.8bf”
   Twirl 20.0 - from the file “Standard MultiPlugin.8bf”
   U3D 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “U3D.8bi”
   Underpainting 20.0 - from the file “Filter Gallery.8bf”
   Vanishing Point 20.0 - from the file “VanishingPoint.8bf”
   Variance 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “statistics.8ba”
   Virtual Reality Modeling Language | VRML 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “U3D.8bi”
   Water Paper 20.0 - from the file “Filter Gallery.8bf”
   Watercolor 20.0 - from the file “Filter Gallery.8bf”
   Wave 20.0 - from the file “Standard MultiPlugin.8bf”
   Wavefront|OBJ 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “U3D.8bi”
   WIA Support 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “WIASupport.8li”
   Wind 20.0 - from the file “Standard MultiPlugin.8bf”
   Wireless Bitmap 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “WBMP.8bi”
   ZigZag 20.0 - from the file “Standard MultiPlugin.8bf”
Optional and third party plug-ins: NONE
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load: NONE
Extensions:
   com.adobe.Butler.backend  2.1.1 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2019\Required\CEP\extensions\com.adobe.Butler.backend\index.html”
   com.adobe.inapp.purchase  1.0.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_3_0_231\purchaseStock.html”
   com.adobe.stock.panel.licensing  0.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2019\Required\CEP\extensions\com.adobe.stock.panel.licensing\index.html”
   Libraries  1.0.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_3_0_231\index.html”
   New Document  2.5.1 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.adobe.ccx.fnft-2.5.1\fnft.html?v=2.5.1.8”
   com.adobe.inapp.typekit.purchase  1.0.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_3_0_231\purchaseTypekit.html”
   Home  2.5.1 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.adobe.ccx.start-2.5.1\index.html?v=2.5.1.102”
   Adobe Color Themes  6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2019\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
   Export As  4.6.3 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2019\Required\CEP\extensions\com.adobe.photoshop.crema\index.html”
Installed TWAIN devices: NONE
Views
17.9K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe
Guest
Nov 15, 2018 Nov 15, 2018
Hi
Sounds similar to this thread
Photoshop Upgrade 20.0.1: not working
May I suggest you report the bug here
Photoshop Family Customer Community
Votes
Translate
Translate
Report
Report
Votes
Translate
Translate
Report
Report
wish I saw this work around 30mins ago. Decided to try going back to CC V20.0. Edit now works, but and a very big but....all my actions gone and they are not in Photoshopcc2018/Presets/Actions or in App Data. Arghhhh feeling gutted
Votes
Translate
Translate
Report
Report
wait maybe not doom & gloom, so I fired up CC 2018 which is still installed and all my actions are there, but strangely I cant find the actions under Appdata/Roaming/Adobe/Adobe Photoshop CC 2018/Presets/Actions or under Program Files/Adobe/Adobe Photoshop 2018/Presets/Actions
Votes
Translate
Translate
Report
Report
ok got em back, all good. And the work around to fix the edit issue is to have photoshop open already before doing export from Lightroom
Votes
Translate
Translate
Report
Report
New Here ,
Hi - I lost my actions as well, after reverting to Photoshop 20.0. I took your suggestion and booted Photoshop cc2018 and they are all there (whew!) but the default editor in LR is still PS cc2019. Did you manage to port the actions over to 2019 somehow? Thanks for any help.
Votes
Translate
Translate
Report
Report
New Here ,
Nov 27, 2018 Nov 27, 2018
Go to your Photoshop program files and copy Presets and Plugins folders onto your desktop. Update/reinstall Photoshop then copy and paste back into program files. I learnt this to my peril a few times.
Votes
Translate
Translate
Report
Report
Community Expert ,
Are these camera raw files or.....?
Votes
Translate
Translate
Report
Report
raw files edited in Lightroom and then exported to Photohop via "edit in Photoshop" option from Lightroom
Votes
Translate
Translate
Report
Report
Community Expert ,
Once the raw files open in photoshop under Image>Mode what is the Bit Depth and Color Mode?
Votes
Translate
Translate
Report
Report
16bit RGB
Votes
Translate
Translate
Report
Report
Community Expert ,
Also, if you haven't restarted your computer after the update, see if that solves the issue.
Votes
Translate
Translate
Report
Report
restarted many times...as I said, the work around of having photoshop started Before doing the export from Lightroom is working
Votes
Translate
Translate
Report
Report
Explorer ,
Yes, this exactly the problem I experienced and your work around works perfectly.
Surely this would have been a basic test that would have been carried out prior to deploying the software release.
When can we expect a fix to be deployed?..
Votes
Translate
Translate
Report
Report
Explorer ,
Dec 15, 2018 Dec 15, 2018
Downloaded update to Lightroom yesterday (Ver 8.1) and problem is still there...
Votes
Translate
Translate
Report
Report
LEGEND ,
Votes
Translate
Translate
Report
Report
Explorer ,
Nov 19, 2018 Nov 19, 2018
Sadly, the 20.0.1 release hasn't fixed the problem outlined in the OP. I still have it and am having to use the workaround.
Votes
Translate
Translate
Report
Report
Participant ,
Nov 20, 2018 Nov 20, 2018
I am having the same problem... This is completely ridiculous when we are paying top dollar for this...
Votes
Translate
Translate
Report
Report
Having the same issue and even the work around isnt helping or working!! Doesnt matter what i do i cant edit the photos in photoshop at all. frustrating.
Votes
Translate
Translate
Report
Report
New Here ,
Dec 12, 2018 Dec 12, 2018
Hey I know this is kind of late but I had success opening the image
"as a smart object in photoshop"
(from the same menu) when I was in Lightroom...
hope this helps...
the workaround did not work for me either.
Votes
Translate
Translate
Report
Report
New Here ,
Same Issue
Votes
Translate
Translate
Report
Report
New Here ,
Nov 23, 2018 Nov 23, 2018
Same problem for me and the workaround doesn't work either.
Votes
Translate
Translate
Report
Report
Explorer ,
Same issue here - as long as I start Photoshop before doing an edit, I'm OK - but if Photoshop is launched from Lightroom, no go.  How is this basic functionality not tested?
Votes
Translate
Translate
Report
Report
Advocate ,
I do not see the issue on my system. How about resetting your preferences.I find sometimes pulling the preferences forward is not always the best option. Also make sure that Lightroom is the latest too.  I think sometimes our issues stem from versions not aligned. (I would do this prior to uninstalling then reinstalling the applications.)
Votes
Translate
Translate
Report
Report
