Hi, I am a newbee and hope someone can help me. Have been using Photoshop for six months with no real problems. My workflow is Bridge -Camera Raw-Photoshop...Simple, after a recent update I view photos in Bridge. select, go to Camera raw Basic adjustments..( Camera Raw is set up for Smart Object ) I click on open object to go to Photoshop, but when it opens all actions are greyed out in the Layer and Image drop downs, so I can't flatten image, duplicate image or open smart object via copy. I have checked settings nothing seems out of order. Can anyone help. Thanks in advance. Barry
Yes, you can revert to an earlier version. In Adobe Creative Cloud app (where you see your installed apps) In the Photoshop line, click on the down facing chevron, then click "manage" and choose "earlier versions" and pick the one you want.
Can you show some screen shots of what you're seeing: full screen, file open, and menus that are grayed out?
Hi Chuck thanks not sure how I am supposed to reply through forum or email.
Regards Barry Jones
Sent from Mail<https://go.microsoft.com/fwlink/?LinkId=550986> for Windows 10
On the forum. Do a screen shot and just paste it into your post.
Same as this issue.
As mentioned by Jeff Arola, starting PS first is the work around.
Hi Thanks again. Can the last update be deleted ?? I have only had this problem since an update a few days ago …..
Thanks KR, it all seems to be working the way it was before the update. .Thanks to all Cheers
And this only happens with images that are opened as Smart Objects? Regular files open okay? The you tried to reset your preferences in both Photoshop and Camera Raw?
Are you able to double-click on the Smart Object and have the file re-open in Adobe Camera Raw? What happens when you right-click on the Smart Object?
Thanks for all your help so far. Joseph, No double click won't work. This morning I went through original workflow Br, -Camera raw- Ps. when image opened up in Ps layer drop was fine it was highlighted, but then greyed out. Tools still work but can't flatten, duplicate anything. Now, I have found that, if I just open Ps, open new, choose image ( although it dose not seem to read Raw Files) it opens image in Camera Raw and when you go to photo shop everything works ?? so wash up, is I can get it to work but have to take long way around because I have to write down file number, because I can't see the raw image in Ps open new. Regards Barry
P.S Chuck, I have Camera Raw set to open as smart object. I must say ever thing has worked fine up until a few days ago when I believe there were updates to Br, and Ps not sure if there was one for Camera Raw. Thanks
This seems very similar to problems some users have reported when opening images from Lightroom into photoshop.
Just started with the last photoshop 20.01 update for them. Adobe is still investigating the cause.
What happens if you start photoshop before using Bridge/Camera Raw and Open Object?
Hi Jeff, yes if I go straight to Ps and open an image it opens it in Camera Raw and then I go to Ps all the drop downs are working. But have just tried to edit a photo using smart object via copy to darken some rocks and when using brush tool it seemed to blur rocks. But yes it has only happened in last few days since an update. Regards
