New to launch and struggling to find any documentation/clarification with the following ..I suspect it's using custom code but no info on how to set the value.
Looking to define custom data elements to then use to populate prop/evars eg.
How would I define pagename element which simply takes the first element from the path and appends with another string value or similarly checks for hostname and modifies
Solved! Go to Solution.
You can access custom variables inside the s object. For example:
s.eVar1 = 'My custom value';
You can access data elements using the _satellite.getVar() method. So to assign a data element to an eVar in custom code:
s.eVar1 = _satellite.getVar('custom data element');
More information on getVar can be found here:
https://docs.adobelaunch.com/client-side-information/launch-object-reference#launch-object-reference
