New Mac, 10.13.6, Illustrator CC 23.01, greyscale. Using 100% black in a shape I normally get 100% black. If I make a gradient with 100% black I only get≈70% black. If I create something as stuped as a gradient 100% black to 100% black the filling is still only≈70%. The transparency is 100% too. I've opened it in Photoshop and, yes it's only≈70% black. If I use a color mix I get the same result in a normal filling as in a gradient. No, I'm not new with these programs.
Gabriel
Gabriel,
Maybe the silly old list (if no brighter suggestions appear).
If things that should work simply refuse to (all possibilities exhausted including the A) - C) below (and carefully making sure you are performing (all) the needed things)), you may try (the relevant part(s) of) the list 1) - 6) below.
Sometimes, (certain) things may fail or stop working for no apparent reason. When the (other) possible reasons/cures fail to work, it may be some kind of (temporay or permanent) corruption, or eve
...Copy link to clipboard
Gabriel,
Sometimes, (certain) things may fail or stop working for no apparent reason. When the (other) possible reasons/cures fail to work, it may be some kind of (temporay or permanent) corruption, or even some inconvenient preference setting(s), which may be cured with something on the following list set up in an attempt to provide a catchall solution for otherwise unsolvable cases. It starts with a few easy and harmless suggestions 1) and 2) for milder cases, and goes on with two alternative ways 3) and 4) of resetting preferences to the defaults (easily but irreversibly and more laboriously but more thoroughly and also reversibly), then follows a list 5) of various other possibilities, and it ends with a full reinstallation 6). If no other suggestions work, or if no other suggestions appear, you may start on the list and decide how far to go and/or which may be relevant.
The following is a general list of things you may try when
A) The issue is not in a specific file,
B) You have a printer correctly installed, connected, and turned on if it is physical printer (you may use Adobe PDF/Acrobat Distiller as the default printer with no need to have a printer turned on, obviously you will need to specify when you actually need to print on paper), and
C) It is not caused by issues with opening a file from external media.
You may have tried/done some of them already; 1) and 2) are the easy ones for temporary strangenesses, and 3) and 4) are specifically aimed at possibly corrupt/inconvenient preferences); 5) is a list in itself, and 6) is the last resort.
If possible/applicable, you should save current artwork first, of course.
1) Close down Illy and open again;
2) Restart the computer (you may do that up to at least 5 times);
3) Close down Illy and press Ctrl+Alt+Shift/Cmd+Option+Shift during startup (easy but irreversible);
4) Move the folder (follow the link with that name) with Illy closed (more tedious but also more thorough and reversible), for CS3 - CC you may find the folder here:
https://helpx.adobe.com/illustrator/kb/preference-file-location-illustrator.html
5) Look through and try out the relevant among the Other options (follow the link with that name, Item 7) is a list of usual suspects among other applications that may disturb and confuse Illy, Item 15) applies to CC, CS6, and maybe CS5);
Even more seriously (this may be serious because you may need to restore plugins and whatnot afterwards if you have customized things), you may:
6) A) Uninstall (ticking the box to delete the preferences if applicable), B) run the Cleaner Tool (if you have CS3/CS4/CS5/CS6/CC), and C) reinstall. You may try without step B), but sometimes it is needed, because otherwise things may linger.
As it appears from this thread, it may be worth repeating this if it fails to help the first time:
https://forums.adobe.com/thread/2283530
To uninstall:
Cleaner Tool:
It's hard to say if I'm stuped or you a genius (or both) I've bin sitting with the support for more than one hour, reinstalled Illustrator and cleaned unviable files etc and all I had to do was making a new file, pasting the design into it and black is black again. THANKS!
It is hardly hard to say, Gabriel: those issues can be rather tricky and evasive, and the (multiple) list with its crucial starter options builds on experience(s) and insight(s) gained over most of this Millennium by friends in this forum and (the sillier) one of the two that went before it. Kurt knows what I mean.
And you are welcome.
Can you share a sample .ai file?
Have you checked your appearances panel to see if maybe something is grouped? Sometime ungrouping can show underlying transparencies.
