Hello,
Is there a way to combine 2 people tags. I went through and was tagging friends and I incorrectly spelled the name and continued adding pictures. Later I added the name once again with the correct spelling not remembering that I had already added it incorrectly. Now I have some of the images under one people tag and other under a different one. I would like to combine both of them, then delete the incorrectly spelled one.
Thank you.
Did you apply people tags by naming stacks in People view? If yes, you can select the stacks in Named people view you want to merge by holding down the Ctrl/Cmd key. After you have selected them, look for "Merge People" option at the bottom panel and click it. It will ask you for the name again where you can enter or select the correct name.
Somya
