I have a duplicate field on many pages. How do I capture that value to to a different field based on a check box. The duplicate fields have the #0, #1 after them. I tried with and without that and without that and can't get it work. Seems to only want a unique field name.
The "#0", "#1" notation means those fields have the same name, and therefore the same value. If you want to access them just drop that part from the field's name in your code and it should work. If it doesn't, post your full code and/or the actual file.
I thought I had done it that way, but I must not have because it's working fine now. Thanks.
