2 Replies Latest reply on Mar 24, 2008 2:52 AM by RoboColum(n)
    Topic titles in *.xpj project files
    veenamj
      I am facing an issue in a Robohelp project file that I am currently working on.
      I have to convert source files using a tool that gives me HTML files. I have to copy these HTML files into the project folder that contains the project file. Since the files are already imported in the project file, I need not import these files into the project file.
      However, there is a change in the html titles. Ideally, the title should be the same as the filename without the '*.html' extension.
      It so happens that every time I copy the HTML files into the folder that contains the project file and start work on the project file. I get a message 'Building File List.....' that appears at the bottom of the project file and all the titles are changed. I have to manually change titles.
      It would be of great help if I could get any solution for this issue.
      Thanking you in advance.
