• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
1
How can I disable/supress "Secure warning" dialog box
Engaged ,
Nov 18, 2018 Nov 18, 2018
At the recommendation of my host provider, I recently updated my website from http:// to a secure website https://. At the time I did this I did not anticipate that it would break all the old http:// slideshow links I had imbedded in i-frames. After finding an replacing almost 300 instances of http: with https: the website is 99% back to normal. However, I still get a "Secure warning" dialog box on more than 60 pages of photography slide-shows. See below.
The dialog box times out in approximately 10 seconds and disappears.
After hours of trying to determine how to fix theses slide shows, I have determined that the common denominator is that the slide shows that give this warning were all created with older slide show tools. I plan to update my website to responsive design in the near future whereby I will recreate these slide shows. However, is there any way to suppress the display of the warning dialog until I update my website. It appears to have no affect on the slide shows displaying correctly.
Thank you in advance,
Jim
[please refrain from PII and 3rd party URLs in this area - Moderator]
Views
630
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
The warning is generated by the browser, so unless you contact every user of your site and ask them to change the security settings, (only joking), but it will give you an idea of how impossible it is.
Your only solution would be to go through all links to external content and ensure they are https, check that everything is within the https folder, (scripts, assets, etc). iframe content should also be within your https folder.
Votes
Translate
Translate
Report
Report
Engaged ,
Not the answer I was looking for . I have already done a find and replace on all http: to https: As far as Dreamweaver is concerned, there are no more instances of http: but I still get the warnings on 60% of my slideshows.
After I did the find and replace I did a global synchronization for my entire site. This fixed 40% of the slide shows. Besides http:, what else can cause a secure content warning. The link below is an example of a slide show that has no http: links but still gives the warning.
San Francisco - Classic Color Views : Photography By James Palik
I have no idea of where to look. I am sure it can be fixed globally once I know what is causing it.
Jim
Votes
Translate
Translate
Report
Report
LEGEND ,
Use the browsers developers tools, to examine the network connections on a problem page. This will show you which scripts, assets, etc are not comming from a secure https connection.
https://developers.google.com/web/tools/chrome-devtools/
Votes
Translate
Translate
Report
Report
Community Expert ,
there is no warning on this link ...
Votes
Translate
Translate
Report
Report
Community Expert ,
Same here!
Wappler, the only real Dreamweaver alternative.
Votes
Translate
Translate
Report
Report
LEGEND ,
Thanks Ben and Birnou, I thought it was just me.
Votes
Translate
Translate
Report
Report
Community Expert ,
have you watched this
Only Secure Content is Displayed - How to remove this error message in Internet Explorer - YouTube
Votes
Translate
Translate
Report
Report
LEGEND ,
Nov 19, 2018 Nov 19, 2018
Not realy a solution though, is it Birnou?
The site owner does not get a warning, because they changed their browsers security setting. Visitors to the site still get the warning.
As I said in my first reply, 'how does one inform visitors to do so', and thats even saying they would consider changing browser security settings, which is highly unlikely.
Votes
Translate
Translate
Report
Report
Community Expert ,
do you get the warning, nor Ben, nor I ... and I was thinking nor you ... recieve any information ?
so before going further into investigation... I asked the OP to turn off the alert... and see what's up ?
Votes
Translate
Translate
Report
Report
LEGEND ,
By turning off the warning, the OP has no way of knowing which pages are giving the warning to site visitors.
It is purerly academic now I think, as the OP was trying to contact Nancy in another thread, so she is probably looking into the problem, (off forum).
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
it was just to see if the OP still gets the warning ?
Votes
Translate
Translate
Report
Report
Enthusiast ,
Have a look at this site:
https://www.whynopadlock.com/b881210f-9603-42ce-a3c1-2ec919960a80
It finds, for example, that javascript files are being referenced through http on your San Francisco page.
Votes
Translate
Translate
Report
Report
