When I open PDF the page loads fine. when I try to modify it, such as Fill & Sign it goes to a page that looks like this and I cannot get it to show the document itself, or sign it
Hi marks,
As per the issue description mentioned above, you are facing issue when tyring to sign a pdf using fill and sign, is that correct?
Could you check if an update is available for reader using "Check for updates" option under "Help" menu, You may also download updates from here: Adobe software and product updates Reboot the machine after installing update and try again.
You may also refer to the following forum threads discussing the similar issue:
PDF Disappearance when using Fill & Sign..HELP!
Fill & Sign does not load the file and displays blank screen
Let us know if you need any help.
Shivam
