I recently updated Adobe Premier pro 2019 to the latest version, alongside Media Encoder 2019. After doing so I experience the blue screen of death with error code: BAD_POOL_CALLER. This happened three times before adobe premier pro completely crashed.
Adobe premier pro 2018 was working fine and continues to when I launch this older version. And I had been running premier pro 2019 for a week or so with no errors till this update.
When I try and open premier pro it stalls on importerQuickTime.prm, then crashes. I have tried renaming the plugins folder to plug-in_old, this didnt work.
I have tried deleting Temp folders and restarting. I have tried running as administrator. All didn’t work
I have also tried entirely resetting my computer to factory settings. When I did this adobe premier pro ran for about 30mins then I got another blue screen of death, this time with error code: KERNEL_MODE_HEAP_CORRUPTION. Then when it restarted premier pro crashed again at start screen.
Please I really need this fixed.
Proccessor: intel(R) Xeon(R) CPU E5-2690 v2 @3.00GHZ 3.00GHZ (2 Processors)
RAM: 128 GB
Graphics Card: GeForce GTX 1060 3GB (running on latest driver update)
I can confirm that deleting this file on the user account that's preventing Adobe Premiere Pro will work to fix the problem:
C:\Users\YOUR USER FOLDER\AppData\Roaming\Adobe\Common\Essential Sound/SharedTags
If you can't get there, go to any open folder and at the top under View;check show hidden files.
This file will NOT delete just by right clicking and deleting it. It will say it cannot be deleted because it's in use. Even with closing all Adobe related files in task manager, it still was unable
...Copy link to clipboard
Same. I haven't found a solution yet. Hopefully Adobe helps us out.
Hi communicationalpha,
Can you find the file here? %APPDATA%\Adobe\Common\Essential Sound\SharedTags.json
If so, please remove it and see if the situation returns to normal after restarting Premiere Pro.
Kevin
This file will NOT delete just by right clicking and deleting it. It will say it cannot be deleted because it's in use. Even with closing all Adobe related files in task manager, it still was unable to be deleted because 'System' is using it.
Thank YOU!
