5 Replies Latest reply on Apr 23, 2008 8:14 PM by flashharry!
    md5 hashing in flex
    logindude
      It's sad that flex does not have built in functionality for cryptography.
      i need to make a hash with a key, like this java function.
      i'v seen action scripts with md5 hashing but not with key. So i need help with that.
      Or is it possible to call java code from flex?
      private String getHash(String data, String key) {
      StringBuffer sb= new StringBuffer();
      MessageDigest md5;
      try {
      md5 = MessageDigest.getInstance("MD5");
      md5.update(data.getBytes());
      byte result[] = md5.digest(key.getBytes());
      for (int i = 0; i < result.length; i++) {
      String s = Integer.toHexString(result );
      int length = s.length();
      if (length >= 2) {
      sb.append(s.substring(length - 2, length));
      } else {
      sb.append("0");
      sb.append(s);
      md5.reset();
      } catch (NoSuchAlgorithmException e) {
      e.printStackTrace();
      return sb.toString();
        • 1. Re: md5 hashing in flex
          goldman-x
          There are several crypto libraries available for Flex. Google for 'flex crypto library' and your prayers will be answered!
          • 2. Re: md5 hashing in flex
            meev82
            Hi...
            http://crypto.hurlant.com/
            This link contain an usefull crypto library made in as3. Maybe it can help you...
            • 3. Re: md5 hashing in flex
              logindude Level 1
              nope im sorry to say that it does'nt help since i have to hash with a "key" as you might see in the example code i showed. The reason for supplying this key is because the webservice im trying to use requires it. I have checked both hurlant.com and googles crypto lib. and i can't see that they have added this functionality.
              • 4. md5 hashing in flex
                slaingod Level 1
                Grabbed this from the Flex Facebook api, which is probably from the crypto lib mentioned... in most cases the 'key' is simply appended to the data you are hashing, as in the Flex Facebook API:
                s += _fb.secret;
                return MD5.hash( s );
                Adobe Systems Incorporated(r) Source Code License Agreement
                Copyright(c) 2005 Adobe Systems Incorporated. All rights reserved.
                Please read this Source Code License Agreement carefully before using
                the source code.
                Adobe Systems Incorporated grants to you a perpetual, worldwide, non-exclusive,
                no-charge, royalty-free, irrevocable copyright license, to reproduce,
                prepare derivative works of, publicly display, publicly perform, and
                distribute this source code and such derivative works in source or
                object code form without any attribution requirements.
                The name "Adobe Systems Incorporated" must not be used to endorse or promote products
                derived from the source code without prior written permission.
                You agree to indemnify, hold harmless and defend Adobe Systems Incorporated from and
                against any loss, damage, claims or lawsuits, including attorney's
                fees that arise or result from your use or distribution of the source
                code.
                THIS SOURCE CODE IS PROVIDED "AS IS" AND "WITH ALL FAULTS", WITHOUT
                ANY TECHNICAL SUPPORT OR ANY EXPRESSED OR IMPLIED WARRANTIES, INCLUDING,
                BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
                FOR A PARTICULAR PURPOSE ARE DISCLAIMED. ALSO, THERE IS NO WARRANTY OF
                NON-INFRINGEMENT, TITLE OR QUIET ENJOYMENT. IN NO EVENT SHALL MACROMEDIA
                OR ITS SUPPLIERS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
                EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
                PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
                OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
                WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
                OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOURCE CODE, EVEN IF
                ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
                package com.adobe.crypto {
                import com.adobe.utils.IntUtil;
                * The MD5 Message-Digest Algorithm
                * Implementation based on algorithm description at
                * http://www.faqs.org/rfcs/rfc1321.html
                public class MD5 {
                * Performs the MD5 hash algorithm on a string.
                * @param s The string to hash
                * @return A string containing the hash value of s
                * @langversion ActionScript 3.0
                * @playerversion Flash 9.0
                * @tiptext
                public static function hash( s:String ):String {
                // initialize the md buffers
                var a:int = 1732584193;
                var b:int = -271733879;
                var c:int = -1732584194;
                var d:int = 271733878;
                // variables to store previous values
                var aa:int;
                var bb:int;
                var cc:int;
                var dd:int;
                // create the blocks from the string and
                // save the length as a local var to reduce
                // lookup in the loop below
                var x:Array = createBlocks( s );
                var len:int = x.length;
                // loop over all of the blocks
                for ( var i:int = 0; i < len; i += 16) {
                // save previous values
                aa = a;
                bb = b;
                cc = c;
                dd = d;
                // Round 1
                a = ff( a, b, c, d, x[i+ 0], 7, -680876936 ); // 1
                d = ff( d, a, b, c, x[i+ 1], 12, -389564586 ); // 2
                c = ff( c, d, a, b, x[i+ 2], 17, 606105819 ); // 3
                b = ff( b, c, d, a, x[i+ 3], 22, -1044525330 ); // 4
                a = ff( a, b, c, d, x[i+ 4], 7, -176418897 ); // 5
                d = ff( d, a, b, c, x[i+ 5], 12, 1200080426 ); // 6
                c = ff( c, d, a, b, x[i+ 6], 17, -1473231341 ); // 7
                b = ff( b, c, d, a, x[i+ 7], 22, -45705983 ); // 8
                a = ff( a, b, c, d, x[i+ 8], 7, 1770035416 ); // 9
                d = ff( d, a, b, c, x[i+ 9], 12, -1958414417 ); // 10
                c = ff( c, d, a, b, x[i+10], 17, -42063 ); // 11
                b = ff( b, c, d, a, x[i+11], 22, -1990404162 ); // 12
                a = ff( a, b, c, d, x[i+12], 7, 1804603682 ); // 13
                d = ff( d, a, b, c, x[i+13], 12, -40341101 ); // 14
                c = ff( c, d, a, b, x[i+14], 17, -1502002290 ); // 15
                b = ff( b, c, d, a, x[i+15], 22, 1236535329 ); // 16
                // Round 2
                a = gg( a, b, c, d, x[i+ 1], 5, -165796510 ); // 17
                d = gg( d, a, b, c, x[i+ 6], 9, -1069501632 ); // 18
                c = gg( c, d, a, b, x[i+11], 14, 643717713 ); // 19
                b = gg( b, c, d, a, x[i+ 0], 20, -373897302 ); // 20
                a = gg( a, b, c, d, x[i+ 5], 5, -701558691 ); // 21
                d = gg( d, a, b, c, x[i+10], 9, 38016083 ); // 22
                c = gg( c, d, a, b, x[i+15], 14, -660478335 ); // 23
                b = gg( b, c, d, a, x[i+ 4], 20, -405537848 ); // 24
                a = gg( a, b, c, d, x[i+ 9], 5, 568446438 ); // 25
                d = gg( d, a, b, c, x[i+14], 9, -1019803690 ); // 26
                c = gg( c, d, a, b, x[i+ 3], 14, -187363961 ); // 27
                b = gg( b, c, d, a, x[i+ 8], 20, 1163531501 ); // 28
                a = gg( a, b, c, d, x[i+13], 5, -1444681467 ); // 29
                d = gg( d, a, b, c, x[i+ 2], 9, -51403784 ); // 30
                c = gg( c, d, a, b, x[i+ 7], 14, 1735328473 ); // 31
                b = gg( b, c, d, a, x[i+12], 20, -1926607734 ); // 32
                // Round 3
                a = hh( a, b, c, d, x[i+ 5], 4, -378558 ); // 33
                d = hh( d, a, b, c, x[i+ 8], 11, -2022574463 ); // 34
                c = hh( c, d, a, b, x[i+11], 16, 1839030562 ); // 35
                b = hh( b, c, d, a, x[i+14], 23, -35309556 ); // 36
                a = hh( a, b, c, d, x[i+ 1], 4, -1530992060 ); // 37
                d = hh( d, a, b, c, x[i+ 4], 11, 1272893353 ); // 38
                c = hh( c, d, a, b, x[i+ 7], 16, -155497632 ); // 39
                b = hh( b, c, d, a, x[i+10], 23, -1094730640 ); // 40
                a = hh( a, b, c, d, x[i+13], 4, 681279174 ); // 41
                d = hh( d, a, b, c, x[i+ 0], 11, -358537222 ); // 42
                c = hh( c, d, a, b, x[i+ 3], 16, -722521979 ); // 43
                b = hh( b, c, d, a, x[i+ 6], 23, 76029189 ); // 44
                a = hh( a, b, c, d, x[i+ 9], 4, -640364487 ); // 45
                d = hh( d, a, b, c, x[i+12], 11, -421815835 ); // 46
                c = hh( c, d, a, b, x[i+15], 16, 530742520 ); // 47
                b = hh( b, c, d, a, x[i+ 2], 23, -995338651 ); // 48
                // Round 4
                a = ii( a, b, c, d, x[i+ 0], 6, -198630844 ); // 49
                d = ii( d, a, b, c, x[i+ 7], 10, 1126891415 ); // 50
                c = ii( c, d, a, b, x[i+14], 15, -1416354905 ); // 51
                b = ii( b, c, d, a, x[i+ 5], 21, -57434055 ); // 52
                a = ii( a, b, c, d, x[i+12], 6, 1700485571 ); // 53
                d = ii( d, a, b, c, x[i+ 3], 10, -1894986606 ); // 54
                c = ii( c, d, a, b, x[i+10], 15, -1051523 ); // 55
                b = ii( b, c, d, a, x[i+ 1], 21, -2054922799 ); // 56
                a = ii( a, b, c, d, x[i+ 8], 6, 1873313359 ); // 57
                d = ii( d, a, b, c, x[i+15], 10, -30611744 ); // 58
                c = ii( c, d, a, b, x[i+ 6], 15, -1560198380 ); // 59
                b = ii( b, c, d, a, x[i+13], 21, 1309151649 ); // 60
                a = ii( a, b, c, d, x[i+ 4], 6, -145523070 ); // 61
                d = ii( d, a, b, c, x[i+11], 10, -1120210379 ); // 62
                c = ii( c, d, a, b, x[i+ 2], 15, 718787259 ); // 63
                b = ii( b, c, d, a, x[i+ 9], 21, -343485551 ); // 64
                a += aa;
                b += bb;
                c += cc;
                d += dd;
                // Finish up by concatening the buffers with their hex output
                return IntUtil.toHex( a ) + IntUtil.toHex( b ) + IntUtil.toHex( c ) + IntUtil.toHex( d );
                * Auxiliary function f as defined in RFC
                private static function f( x:int, y:int, z:int ):int {
                return ( x & y ) | ( (~x) & z );
                * Auxiliary function g as defined in RFC
                private static function g( x:int, y:int, z:int ):int {
                return ( x & z ) | ( y & (~z) );
                * Auxiliary function h as defined in RFC
                private static function h( x:int, y:int, z:int ):int {
                return x ^ y ^ z;
                * Auxiliary function i as defined in RFC
                private static function i( x:int, y:int, z:int ):int {
                return y ^ ( x | (~z) );
                * A generic transformation function. The logic of ff, gg, hh, and
                * ii are all the same, minus the function used, so pull that logic
                * out and simplify the method bodies for the transoformation functions.
                private static function transform( func:Function, a:int, b:int, c:int, d:int, x:int, s:int, t:int):int {
                var tmp:int = a + int( func( b, c, d ) ) + x + t;
                return IntUtil.rol( tmp, s ) + b;
                * ff transformation function
                private static function ff ( a:int, b:int, c:int, d:int, x:int, s:int, t:int ):int {
                return transform( f, a, b, c, d, x, s, t );
                * gg transformation function
                private static function gg ( a:int, b:int, c:int, d:int, x:int, s:int, t:int ):int {
                return transform( g, a, b, c, d, x, s, t );
                * hh transformation function
                private static function hh ( a:int, b:int, c:int, d:int, x:int, s:int, t:int ):int {
                return transform( h, a, b, c, d, x, s, t );
                * ii transformation function
                private static function ii ( a:int, b:int, c:int, d:int, x:int, s:int, t:int ):int {
                return transform( i, a, b, c, d, x, s, t );
                * Converts a string to a sequence of 16-word blocks
                * that we'll do the processing on. Appends padding
                * and length in the process.
                * @param s The string to split into blocks
                * @return An array containing the blocks that s was
                * split into.
                private static function createBlocks( s:String ):Array {
                var blocks:Array = new Array();
                var len:int = s.length * 8;
                var mask:int = 0xFF; // ignore hi byte of characters > 0xFF
                for( var i:int = 0; i < len; i += 8 ) {
                blocks[ i >> 5 ] |= ( s.charCodeAt( i / 8 ) & mask ) << ( i % 32 );
                // append padding and length
                blocks[ len >> 5 ] |= 0x80 << ( len % 32 );
                blocks[ ( ( ( len + 64 ) >>> 9 ) << 4 ) + 14 ] = len;
                return blocks;
                • 5. Re: md5 hashing in flex
                  flashharry! Level 1
                  Any way to make an MD5 has from a file reference.
                  I need to get the hash of the bytes, similar to the osx terminal command md5
                  Dean
