6 Replies Latest reply on Nov 22, 2018 8:15 AM by johnrellis
    Incorrect DateTime in EXIF info (Samsung S9+ Front Camera)
    maxw58450824 Level 1
      The original file from Samsung S9+ Front Camera has in JPG correct DateTime in a file (EXIF).
      All files exported in Lightroom 8.0 from Samsung S9+ Front Camera to JPG has incorrect DateTime because it is a current date + orginal time :-(
      Files exported from Rear Camera are OK ;-)
        • 1. Re: Incorrect DateTime in EXIF info (Samsung S9+ Front Camera)
          johnrellis Most Valuable Participant
          Note that the EXIF field DateTime is defined by the standard to be the date/time that any photo application modified the photo (including creating it) -- it is not necessarily the capture date (when the shutter was pressed).   The EXIF field DateTimeOriginal contains the capture date.
          When a camera first creates a JPEG, it typically sets DateTime to the same value as DateTimeOriginal. But when LR exports a photo, it sets DateTime to the current time, as specified to the standard.
          • 2. Re: Incorrect DateTime in EXIF info (Samsung S9+ Front Camera)
            I have a jpg file from Samsung S9+ Front Camera. EXIF info (from IrfanView):
            DateTime - 2018-08-13 08:26:59
            DateTimeOriginal - 2018-08-13 08:26:59
            DateTimeDigitized - 2018-08-13 08:26:59
            Then I imported file to Lightroom 8.0 and exported file to jpg. EXIF info from exported file:
            DateTime - 2018:11:21 13:52:06
            Files from Samsung S9 Rear Camera, S7 (front+rear), Canon 6D are correct because in EXIF is DateTimeOriginal and DateTimeDigitized. But files exported from LR only from front camera S9+ has only current export date :-(
            Files without correct EXIF info DateTime are incorrectly sorted in Google Photos :-(
            • 3. Re: Incorrect DateTime in EXIF info (Samsung S9+ Front Camera)
              ManiacJoe Adobe Community Professional
              What are your export settings?
              What other EXIF info is being written to your exported JPGs?
              • 4. Re: Incorrect DateTime in EXIF info (Samsung S9+ Front Camera)
                The most efficient way to troubleshoot this is to upload to Dropbox or similar a sample JPEG from the front camera that has never been imported into LR. Post the sharing link here.  We can then determine whether the problem is specific to your LR configuration, a bug in LR, or the JPEG (it's not uncommon for Android photos to fail to conform to industry standards).
                • 5. Re: Incorrect DateTime in EXIF info (Samsung S9+ Front Camera)
                  Files exported from LR:
                  To Hard Drive, Image Format: JPEG, Color Space: sRGB, Quiality: 100, ResizeToFit: 2048x2048, Resoulution: 72, Sharpen for: Screen, Metadata: All Metadata
                  EXIF from orig.jpg (IrfanView):
                  ImageWidth - 3264
                  ImageLength - 1592
                  Make - samsung
                  Model - SM-G965F
                  Orientation - Left bottom
                  XResolution - 72
                  YResolution - 72
                  ResolutionUnit - Inch
                  Software - G965FXXU2BRJ3
                  DateTime - 2018-11-20 22:37:14
                  YCbCrPositioning - Centered
                  ExifOffset - 226
                  ExposureTime - 1/25 seconds
                  FNumber - 1.70
                  ExposureProgram - Normal program
                  ISOSpeedRatings - 320
                  ExifVersion - 0220
                  DateTimeOriginal - 2018-11-20 22:37:14
                  DateTimeDigitized - 2018-11-20 22:37:14
                  MaxApertureValue - F 1.70
                  MeteringMode - Center weighted average
                  Flash - Not fired
                  FocalLength - 2.92 mm
                  FlashPixVersion - 0100
                  ColorSpace - sRGB
                  ExifImageWidth - 3264
                  ExifImageHeight - 1592
                  ExposureMode - Auto
                  White Balance - Auto
                  FocalLengthIn35mmFilm - 25 mm
                  SceneCaptureType - Standard
                  Maker Note (Vendor): -
                  EXIF from exported_from_LR.jpg (IrfanView):
                  Make - samsung
                  Model - SM-G965F
                  XResolution - 72
                  YResolution - 72
                  Software - Adobe Photoshop Lightroom Classic 8.0 (Windows)
                  ExifOffset - 212
                  FNumber - 1.70
                  ExifVersion - 0230
                  ShutterSpeedValue - 1/25 seconds
                  Flash - Not fired
                  ColorSpace - sRGB
                  ExposureMode - Auto
                  Thumbnail: -
                  Compression - 6 (JPG)
                  XResolution - 72
                  YResolution - 72
                  JpegIFOffset - 552
                  JpegIFByteCount - 6154
                  • 6. Re: Incorrect DateTime in EXIF info (Samsung S9+ Front Camera)
                    The problem is that the original JPEG doesn't conform to the EXIF industry standard -- it's storing EXIF:DateTimeOriginal in an invalid format. I forgot that I had diagnosed the same problem with the S9+ front camera two months ago.  You should report this bug to Samsung. See this thread for details and a workaround: Re: Capture time is not correct with new phone
