7 Replies Latest reply on Nov 26, 2018 5:43 PM by janisk1969
    No PPAPI Update for 31.0.0.148
    janisk1969 Level 1
      Yesterday (11/19/18) I updated Flash to 31.0.0.148.  However, when I try to update the PPAPI, all the download link will give me is the "install_flash_player_osx.dmg" file -- even though I click for it through my System Preferences for PPAPI.  Because the PPAPI version doesn't match, I keep getting "upgrade" alerts.    I'm hoping an Adobe employee reads this, and fixes the download.
      Mac OSX 10.14.1, Safari 12.0.1, Chrome 70.0.3538.102.
        • 1. Re: No PPAPI Update for 31.0.0.148
          ridhijain Adobe Employee
          Hi janisk1969,
          The latest version of Flash Player is 31.0.0.153. If you try to perform update through system preferences, it would download the file and you need to install the same. If you want updates to be installed automatically, in system preferences open Flash Player and click on updates tab. Select "Allow Adobe to install updates". Within 24 hours of a new version release, you would get updated to the latest version if you are connected to the internet.
          Thanks!
          • 2. Re: No PPAPI Update for 31.0.0.148
            janisk1969 Level 1
            I checked, and you are correct -- there have been TWO updates in the past few days.  I now have 153.  HOWEVER, the same problem exists; the PPAPI version remains at 122.  Has that side of Flash been eliminated?  Is 122 the latest PPAPI version?  Or did someone forget to upload a 153 version for it?
            • 3. Re: No PPAPI Update for 31.0.0.148
              maria__ Adobe Employee
              I am unable to reproduce.  I did the following:
              1. Install PPAPI version 31.0.0.122
              2. Launched System Preference > Flash Player Settings Manager
              3. In the Updates tab, click Check Now button next to the PAPPI Plugin version
              4. Flash Player checked for an update and displayed the notification that an update was available.
              5. In the Update Available notification, click Yes to update Flash Player
              6. The default browser launched to https://get3.adobe.com/flashplayer/update/ppapiosx
                1. This URL downloads the PPAPI plugin regardless of the user's default browser (which may or may not be a PPAPI-based browser)
              7. Click yellow Update Now button
              8. install_flash_player_osx_ppapi.dmg file downloaded - this is the PPAPI tester
              9. Close System Preferences
              10. Proceed to install PAPPI plugin
              11. After installation completes, launch System Preferences > Flash Player Settings Manager
              12. Navigate to Updates tab = Flash Player PPAPI plugin 31.0.0.153 installed
              Note that Google does embed Flash Player in Chrome and there is no need to install it separately.  The embedded version does not display in the System Preferences > Flash Player Settings Manager > Updates tab, as it's a component of Chrome and not a separate,  manually installed plugin.
              Chrome will also use the most recent version, regardless if it's the embedded or non-embedded version.  To determine which PPAPI plugin Chrome is using, launch Chrome and navigate to chrome:/flash.  Chrome will display various information, including the Flash Player version installed, and Flash Player installed path.  If the path is /Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin, it's using the manually installed version.  If the path is /Users/Your-UserID/Library/Application Support/Google/Chrome/PepperFlash/PPAPI_Flash_Version/PepperFlashPlayer.ppapi it is using the embedded version.
              Maria
              • 4. Re: No PPAPI Update for 31.0.0.148
                janisk1969 Level 1
                Thank you for your reply.
                I had tried to update the PPAPI 3 times before I received your email, operating exactly as you mentioned (as I've done every time).  I got the same results (no PPAPI).    I even tried "fooling" the NPAPI link by changing the N to a P, to see if I'd get the correct version.  Nope.
                After receiving your email, I clicked on the link you embedded.  TWICE it sent down the NPAPI version.
                Any other ideas?
                • 5. Re: No PPAPI Update for 31.0.0.148
                  Which browser do you have configured as the default browser?  It shouldn't matter, but this info will help troubleshooting.
                  What URL are you redirected to when you attempt to go to https://get3.adobe.com/flashpalyer/update/ppapiosx? (copy/paste the link).
                  • 6. Re: No PPAPI Update for 31.0.0.148
                    I was able to reproduce the behaviour you are experiencing on macOS 10.14 (this behaviour is not reproducible on macOS 10.13) and will file a bug for this issue.
                    in the interim, to update Flash Player PPAPI, do the following:
                    1. Launch any browser
                    2. Navigate to https://get.adobe.com/flashplayer/otherversions
                    3. In step 1, select your operating system (Mac OS X 10.10 - 10.14)
                    4. in step 2, select 'FP 31 Mac for Opera and Chromium - PPAPI
                    5. Click the yellow 'Download now' button in the bottom right corner
                    6. Install file is downloaded to the selected download folder
                    • 7. Re: No PPAPI Update for 31.0.0.148
                      janisk1969 Level 1
                      Whoo hoo!  That worked!  Thank you.
