• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
CF file upload problems
Explorer ,
Mar 24, 2008 Mar 24, 2008
Hello, hopefully someone out here will have an answer to this. I am having a problem getting two images to upload to the server. The first image always uploads, but the second one does not. The entry gets put in the database for both image paths, but I can not figure out why the second will not upload. I have attached the code.
Thank you in advance for any help.
Weston
TOPICS
Advanced techniques
Views
519
Translate
Translate
Report
Report
Community guidelines
community guidelines
Explorer , Mar 24, 2008 Mar 24, 2008
For some reason I never thought to check folder permissions. For anyone having this issue later on, double check your folder permissions on the server. I had no write permissions set so once I changed those it uploaded the file.
Votes
Translate
Translate
Contributor ,
Any error msg?
Are you sure that you have the destination directories on your disk?
Votes
Translate
Translate
Report
Report
Explorer ,
Yes, I am positive. The first file uploads fine, it shows up in the directory as it always has. I just added a thumbnail upload slot and that is the part that does not upload. The correct would be file paths go into the database correctly for both with the proper file names, for some reason the second file just does not upload to the specified folder.
Votes
Translate
Translate
Report
Report
Explorer ,
Also, no error message at all. Forgot to mention that.
Votes
Translate
Translate
Report
Report
Explorer ,
Votes
Translate
Translate
Report
Report
Contributor ,
Nice to hear that you have figured out. :)
Votes
Translate
Translate
Report
Report
Guest
Aug 10, 2010 Aug 10, 2010
LATEST
In my case, I was attempting to use a different Username than the owner of the files.  Once changed to the true owner in the site definitions, it all worked.  It had nothing to do with permissions on the specific folders or files.
Votes
Translate
Translate
Report
Report
Resources
Documentation
