1 Reply Latest reply on Nov 28, 2018 11:40 AM by WillBartlett
    Premiere loses a frame with rate stretch when 'Flip' effect is used?
    WillBartlett Level 1
      Hi All,
      I've noticed that Premiere Pro cuts out a frame when I split a clip, then rate stretch a section when using the vertical and horizontal flip effects on a clip that was shot upside down. You'll see what I mean here (I've applied the flip effects to the clips already):
      https://drive.google.com/open?id=1878JERaj8zQ0N0UQbNSwcO92-05jXIYY
      Is there a way to fix this, or is this just a bug? Or am I just not understanding this and this is how it should work?
      (The reason the footage was shot upside down was because it was shot on the Movi in the flipped setup, which is often easier to film with.)
